How Do You Keep A Draw Bar From Spinning?
   / How Do You Keep A Draw Bar From Spinning? #21
This is my homemade multiple use draw bar, receiver hitch, short skidding boom pole, ballast weight bracket, middle buster, sub soil, yet to be invented tool tow bar...
Good luck..
   / How Do You Keep A Draw Bar From Spinning? #23
   / How Do You Keep A Draw Bar From Spinning? #24
   / How Do You Keep A Draw Bar From Spinning? #26
   / How Do You Keep A Draw Bar From Spinning? #27
That would do fine as far as keeping the drawbar from rotating but I am not sure how it would do as a receiver hitch. I prefer a solid square tube.
I think it would be adequate for moving most empty trailer's or some light loads.
   / How Do You Keep A Draw Bar From Spinning? #28
   / How Do You Keep A Draw Bar From Spinning? #29
This is how it was done on the old Ferguson tractors. The old farm trailer my dad towed around with one of these was simply a clevis type hitch. One tongue of the clevis went above the drawbar and the other tongue was below the drawbar. The trailer was attached with a pin that passed through the trailer clevis and the drawbar. You didn't need to stop the drawbar from spinning with this type of arrangement.
   / How Do You Keep A Draw Bar From Spinning? #30
Worked because of the hardware on the lower links.
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
2024 YANMAR TL100VS SKID STEER (A60429)
2024 YANMAR...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2014 Ford Fusion Passenger Car, 2.5L Engine - Only 90,875 Miles (A56438)
2014 Ford Fusion...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
