New member ...looking to buy 24 to 30 hp tractor
   / New member ...looking to buy 24 to 30 hp tractor
When comparing specs the Kioti really is at the top on most items. The BH system looks really solid. How do you like your CK25 ? I think i would get the HST though. Your right....BH can do more than just dig ! Storing won't be a problem...plan on building another shed just for the tractor and implements.
   / New member ...looking to buy 24 to 30 hp tractor #42
I love my tractor. It is one dirt moving little beast. I've had it since 2006. I've moved over 1000 tons of fill dirt and rip-rap, plus many backhoe tasks: tree stumps, buried propane tank, 2 retaining walls, culvert pipe just to name a few backhoe tasks. This spring it's going to be used heavily to build a 6000 gallon koi pond and water fall. It will come in especially handy for setting boulders.
HST is better because of control. But, go to the CK35 if getting HST. I couldn't afford the CK30 or CK35 HST when I bought. So I opted for maximum HP to the ground with the shuttle. PTO HP wasn't a concern for me. I've gotten used to the shuttle. It's not so bad either.
For storage, keep in mind that you'll need space for 2 tractors if you take the backhoe off. That's how big it is. I guess you could park over part of it.
WOW...thats alot of earth moving !! Can you get a thumbnail to fit on the BH bucket ? You just have to learn how to use the equipment at its best limits....something you seem to have mastered !!! Glad you shared your CK25 experiences....this tells me that i wouldn't need more than 30 hp for what i will be doing.
   / New member ...looking to buy 24 to 30 hp tractor #44
Yeah. I built a road through a ravine and needed a tremendous amount of fill. I'd run adds on Craigslist asking for free fill dirt. Got many responses. It took 3 years to get all the fill and put it in place before finishing off the road with 140 tons of crush-n-run. And I was doing this on a steep slope. So steep in fact, that at first I couldn't climb to the tope with the tractor. Dig a little. Fill a little, until I could get to the top. The fill, fill, fill. smooth smooth smooth. Over and over again. I don't think I took photos while building the road, but I think I take some of it finished and posted here somewhere. If you care to you can search for threads I started and you'll see what can be done. But this is true of many users on here, no matter the make. Test them all. A different brand/model might suit you best. If money were no object I'd probably get a bigger Massey. They are really nice machines.
Depending on the backhoe, you can get both mechanical and hydraulic thumbs. I never had the need. Most things can be pinned between the arm and the bucket. I'll be moving boulders with straps.
   / New member ...looking to buy 24 to 30 hp tractor #45
On my 4020R Branson the backhoe subframe mounts at four places..You remove the lower 3 point arms and the two hooks on the subframe then slide onto these mounting places as you back over the subframe. The front of the subframe mounts to a solid round tube on the loader subframe with two flip over brackets with one pin each. The subframe for the backhoe overlaps the loader subframe and fits inside of it. Tractor still has good ground clearance. I just plug hydraulics into one of my rear remotes. Plenty of flow at 1300-1400 rpm for me.
That sounds too much like work! For a light duty backhoe the two pins and on the kioti and the ability to leave the 3 point arms in place makes it real nice, easy and quick to mount and dismount. It takes less than 10 min to take it off and put it back on with the DK Not sure if all the others are this quick but it sure beats having to remove the 3 point like I used to have to do with the JD.
   / New member ...looking to buy 24 to 30 hp tractor #46
I believe Tyler brothers has an action of tractors/attachments/equipment once or twice a year, that might be a way for you to get a good deal as it sounds like you have Mechanical skills being an aircraft mechanic and might be able to check them out at the auction. You would be limited by what is at the auction though
   / New member ...looking to buy 24 to 30 hp tractor #47
im also a new shopper in this size hp and $20,000, and have quotes on 3 small garden tractors between 25hp and 27hp, first was a simplicity legacy xl, diesel 4wd, next was a JD 1025r, last was a kubota b2650. all of these tractors with loaders and mower decks are well under $20,000.
My problem is comparing the specs, and there is no end to moving up. the legacy has a 500lb loader capacity(roll pin 59"high) & 350# 3 pt, the jd has 836lb loader capacity(roll pin 71.2 high) & 681lb 3 pt, the kubota has a 1146lb loader capacity, & 1676lb 3 pt capacity. the tractor physical sizes move up accordingly; simplicity weighs 1130lbs, 58.5" wheel base; JD 1025r weighs 1441 lbs, and a 57.1 wheel base, the kubota weighs 1786 lbs(roll pin 84.6 high), and a 65.6 wheel base. the tire sizes also increase in size.
Dealer service i read is important, from where i live there are 2 dealers of each brand that have good reputations close by(<12 miles). i have owned my JD 420 garden tractor for 28 years, but only have a mower and front snow blade; no 3 point or fel. i have been very happy with it. John Deere is a good company(engineering, parts, service) in my opinion. I have heard the Kubota is also good, but have no first hand experience. simplicity also has a good following, but have a limited offering in equipment the legacy is the largest they offer.
All 3 offer discounts, some more than others; simplicity discount and rebate is about $20,500 list; offered at $18000 or -11% off(maybe more but being the smallest i didn't push as hard)
The JD list for $19745, $17300 or -12.5% off.
The kubota list $23900. offered at $18000or -24.7%.
FROM THE LIST PRICE THE DEALERS ALL ADDED EITHER FREIGHT OR SETUP, BUT THE DISCOUNT PRICE IS NET, NO ADDITIONAL CHARGES). my problem is between the deere and kubota choice; kubota spec's out much better capacity but Deere has the personal name experience. I did re spec a 2 series deere, price went to $22,000 and specs were slightly less than the kubota b2950.
PS, I'm on the fence and sold the faithful JD420 yesterday. ANY ADVISE HERE IN WHICH WAY TO GO?
   / New member ...looking to buy 24 to 30 hp tractor #48
Get as much tractor as you can afford, Trollingfever. I do strongly suggest you look at several other brands than the 3 you've looked at. My personal favorite (this month) in the small CUT/big SCUT range is the Mahindra MAX26XL. You should try one out, as well as Kioti, TYM, MF, and LS. If you really are down to those 3 (all different classes ???), the bota is the better choice just because it's more tractor. The little B's are pretty nice.
   / New member ...looking to buy 24 to 30 hp tractor #49
Gee, Trollingfever, based on what I read, the Kubota would be a no-brainer choice. More tractor, about the same money, and better re-sale down the road. Dah.
   / New member ...looking to buy 24 to 30 hp tractor #50
if my choice were between those 3 The Kabota would be coming home with no doubts what so ever! I also second looking at other brands before making a final choice if you haven't already done so.
2005 Detroit Diesel 100DSEJB 138kVA 3-Phase Diesel Generator (A59228)
2005 Detroit...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
Case 930 Tractor (A59814)
Case 930 Tractor...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2010 CHEVY SILVERADO 3500 HD PICK UP TRUCK (A59575)
2010 CHEVY...
