Well Pumps - Variable Speed?
   / Well Pumps - Variable Speed? #1
Pettrix
High Desert Southwest
Looking to do a well and I have a question about well pumps. I was told that variable speed pumps are the way to go vs the older single speed on/off pumps. Supposedly the variable speed pump keeps constant pressure but uses less power than the old single speed on/off pumps.
I was told to do with a 1.5 HP - 10 GPM pump.
Any input or advice?
   / Well Pumps - Variable Speed? #2
I looked into them a few years back, couldn't justify the extra cost and I wasn't concerned about the water pressure fluctuating. I barely notice the difference.....Mike
   / Well Pumps - Variable Speed? #3
I have gone variable for both a bore (well) and tank pump replacing older pumps. They have quite a few features that make then stand out and for me the most important is the lower current draw on startup. My wiring for the pump house where both pumps live is only 10amp, thank you previous owner, so I want to keep the startup and running current as low as possible for both pumps. I am happy with the results. Ancillary benefits are the more constant pressure and the ability to adjust the pressure. I also expect the pump life to be in excess of what the previous pumps provided. we'll see.
Yes they are more expensive.
As the the sizing, I'm not a pump guy, but if I was I would need a shedload more info. Things like how much head (never too much of that)? What you want to use the water for? How many taps in the system? Etc.
Someone else told me to get a CSV (cycle stop valve) on a standard pump. These valves keep constant pressure and reduce pump wear. This would be option #2 for me.
   / Well Pumps - Variable Speed? #5
I like the NEW style pumps.
Variable speed and only run when water is used. These pump's ramp up based on the water demand and will keep up with each and every faucet that is turned on. They are similar to the on demand hot water heater. Energy cost is lower based primarily on the fact that it takes less current to 'start' when your pump begins to run.
As to why I didn't get one - they are not commonplace (used in most homes) so they are costly. If everyone purchased/had one installed price would be cheaper than the more traditional pump. There is a more involved wiring set-up and it too drives up cost - it takes single phase power and converts it to three phase. Three phase (power) is typically used in most commercial and industrial settings because it is a more efficient way to run electric motors.
I am unsure how they will perform/last using dirty energy I.E. home generator when the power goes out. Some generators like a PTO driven tractor type will vary in voltage when loads are placed on them, most electronics do not like voltage fluctuations. The more expensive permanent generators professionally installed at your home will account for voltage fluctuation and would not present a problem at all. But I am betting that most people out there are using box store simple generators to power their homes during a power outage.
Mother Nature, is ultimately why I went with a traditional pump. Lightning will take out a pump in a hurry regardless of any failsafe that is put into place. So..... that is why I just stuck to the older (cheaper to replace) pump
   / Well Pumps - Variable Speed? #6
Take this opinion with a grain of salt - never seen this in person.
I went to the Website that makes this valve, and watched their animation showing the difference(s) between it and the traditional pump switch. The valve show's the pump running full time when water is run which would lower cycle times and reduce wear. But no matter what- when water is turned off the pump shuts off. Current draw using either type of pump switch is going to consume the same power.
If you use a lot of water, have 6 kids and they a all girls- living in the shower.... I would use this innovative valve.
Still I would use the more traditional design. Even with high demand water usage I would use a normal pressure switch. Just buy an oversized pressure tank, the bigger-the-better. I installed one and it will cycle only one time when my daughter is taking her "what seems to be 4hr shower".
   / Well Pumps - Variable Speed? #7
I've seen variable speed pumps but only for large irrigation projects - center pivot irrigation rounds. Never seen them used for single family dwelling well.
After 32 years, I had to have my home well pump replaced last year. Its a simple single speed submersible pump - maintains plenty of pressure and I never notice any variation in pressure. I'm sure if the variable speed pump would have been better in my situation, the "pump man" would have recommended it.
I suggest you get your advice from a qualified pump replacement company. They will obtain all the necessary data and provide you with correct & appropriate answers for your situation. Any way you decide to go will be pretty darn expensive and you want the best advice available.
   / Well Pumps - Variable Speed? #8
I installed a Grundfos SQE system a few month ago, I am extremely happy with it. I gained a bunch of space under my basement steps also since the system is so small.
Constant Pressure Pump | Grundfos
   / Well Pumps - Variable Speed? #9
Tried this once, but my laptop rebooted itself in the middle of the note. Hate that.
I'd think they should have some brushless pump motors out for these now. That would be the way to go, and it ought to reduce the starting amperage required.
Pumps around here last a long time, as long as the wells are reasonably deep. The shallow wells are the ones requiring frequent pump pulls.
Our pump goes back to 1987/88. That's typical of this area. Almost everyone just a smidget out of town have wells and septic.
Ralph
   / Well Pumps - Variable Speed? #10
Pluses: lower inrush, lower power usage, perhaps more constant pressure
Minuses: Much higher install cost, not much reserve with power loss (small holding tank), much higher failure risk to lightning, energy saving not enough to justify the purchase price
paul
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Landoll 7130 Harrow (A59814)
Landoll 7130...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
White 5100 Planter (A59814)
White 5100 Planter...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
1459 (A57192)
1459 (A57192)
