Adding a winch to 7 ton trailer
   / Adding a winch to 7 ton trailer #11
Do you have large guage cables from your battery to the back of your truck. Just wondering how you power up the trailer winch while the trailer is hooked to the truck. Or, are you talking about two vehicles?
If you have a 7pin or rv plug the center plug is the power supply to trailers or if you have a separate plug. I can't think of the band but there is a really nice plug for about sent assessory. It starts with a A
I think Anderson????
   / Adding a winch to 7 ton trailer #13
If you are saying use your accessory wire in your trailer plug to run a winch I'm afraid that will not work. For a working winch you are in the 100's of amps 400-500A for a 10-12K winch.
   / Adding a winch to 7 ton trailer #14
Yes , I have #6 or # 8 welding lead cable (I don't remember which size) from the battery of my truck all the way back.. The connectors that BCP posted are the connectors I used.. Like on XFaxmans receiver type winch
   / Adding a winch to 7 ton trailer #15
Xfaxman - in the bottom pic. Were you stretching that pickup and making a crew cab - ha,ha. Looks like the Massey must have been connected to the back of the pickup. --------
Almost did. :D
The Massey was chained to the receiver hitch and another chain to the gate post. This was ten years ago and before I put the receiver on the Massey. It was a cottonwood stump that I was going to pull. It broke at ground level which was OK for the back of the dam. Then I hooked onto the tree and drug it out.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
   / Adding a winch to 7 ton trailer #16
I went cheap also. I got a 5000# winch on Amazon for $130 delivered. It's pulled tractors as large as a 900 Ford, a Suburban, a Silverado, and numerous mid sized cars without issue.
Chris
The "cheap" winches seem to have pushed the price point for name brand 8000-9000lb winches down to $300-400.
I've always used 9000lb winches for car recovery - Warn, Ramsey, a cheap HF from before they called them Badlands, and I'm now trying a Ramsey 10k. The weak point in every unit was the solenoids. The older ramseys and even Harbor Freight used an industrial starter solenoid that you could get at Napa, but they were pricey. I had a lot of trouble finding quality replacement solenoids that wouldn't heat up and stick in the closed position. Superwinch has a proprietary solenoid that worries me a bit. Haven't researched replacement costs yet.
Warn touted a "modern electronic relay" which was actually a 93-up Ford starter solenoid that was available everywhere for cheap.
The variables to compare when shipping are horsepower or gearing and line speed. Some of the cheaper winches make up for being underpowered by having a slow line speed. Whereas the Warn was probably the fastest puller of the bunch.
I've used and abused all of mine and never had a motor or gear failure..only electrical issues. The superwinch is fairly new so we'll see how it holds up. Everyone I talk with who has a large Badlands winch loves them, but I don't know how aggressively they're using them.
   / Adding a winch to 7 ton trailer #17
This should do the trick. This is a 20k winch off the front of an army truck. The winch on the back is 45k. Ok maybe a bit overkill. I guess you don't have any good choice besides electric, but I am spoiled with hydraulic winches. image-3090996468.jpg image-213396574.jpg
   / Adding a winch to 7 ton trailer #18
I bought one of the harbor freight 12k winches for my trailer when it was on sale with 20% coupon, think I paid around 250 total with a mounting plate. About 3 years old, use it 2-3 times a year, the only issue is it seemed to drain one battery pretty quickly so I mounted two on my trailer.
   / Adding a winch to 7 ton trailer #19
You guys that are mounting which on the front of trailers how are you powering them?
With a battery or two on the trailer and if so how are you keeping the battery charged?
Do you think this is the best way to go or better to go with making a heavy duty set of jumper cables to run to the truckbattery be better?
   / Adding a winch to 7 ton trailer #20
We always have a spare battery or two around for swapping into truck or equipment. I just throw whatever is charged into a toolbox on the trailer and run the cables through a small hole in the back of the toolbox.
The quickest way I found to secure the cables to battery is to just use vise grips...this allows me to use top post, marine, sidepost or clamp to jumper cables without having to keep track of adapters and bolts. I always had trouble keeping a dedicated battery charged, and we have a multimount setup for the winch so it can be used on several trailers.
Believe it or not, this harbor freight bumper adapter is the bees knees when it comes to adding a receiver mounted winch. Flipped it over and bolted through deck to a crossmember underneath with grade 8 bolts.Its pretty tough - installed it as a temporary fix and it ended up staying on the trailer.
3500 lb. Step Bumper Receiver
More info coming soon! (A56859)
More info coming...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
TANK MANIFOLD (A58214)
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
