A tale of two 5yd dump trucks....
   / A tale of two 5yd dump trucks....
Nice truck G!
My F450 was the same way, as the dump body was the same color as the cab. LOTS of surface rust and paint peeling by the sheet. I painted it glossy black with Rustoleum, but hate it. The gloss makes the rough spots stand out. I'll give it a quick sanding and repaint with flat. I can't tell from the pictures, did you paint yours in flat or semi-gloss?
Good call on the F800. I paid twice as much for half the truck, and had to put a full set of tires and brake on too! But my truck needs to be under CDL (no farm exemption) and I do take it across the state on the regular.
BTW - I like the tarp system you have.
Thanks! I was looking more for something under CDL limits just to make things simpler, but I thought this truck was solid (other than the one spot in the floor!) and wasn't impressed at all with the three trucks I looked at prior, so I went with it.
I'm leaning towards getting a CDL again, but at least I can go with the farm exemption for now.
Congrats, that's a real beauty of a truck, neighbor.
What does insurance run on something like that?
I really would love to have a 3 or 5 yard dump on hand for moving dirt around my own property, and bringing gravel for my 1000' driveway... but funds are tight and I don't have facilities to maintain something that beastly.
Thanks! Insurance sort of depends on the exact weight, and the intended use, but for six months it was a bit under $350 as a farm truck. I'm not sure if it would go up if it was a straight commercial use or not.
I managed to get the floor patched today. Surprisingly, the rest of the floor everywhere else is totally fine, and it's just this one area that's bad. When i started peeling back the mat I was getting worried until I saw it didn't go any further. It had a layer of mud/dirt/rust under the floor mat in this area, so I can only assume it got trapped under the mat, and stayed there for a long time.
I'm thinking that if I have the time at some point in the future I'll pull the seats, remove the rest of the mat and paint the entire floor with POR-15 or something similar to seal it....can't hurt.
So, I cut away the mat and insulation, then scraped all the loose stuff, pried up anything suspect, then vacuumed, scraped some more, etc until I had it pretty clean. I then painted all of the rusty areas with POR-15 right up to where the white paint was intact (you can sort of see the white painted area towards the shifter boot in the pic below, but I trimmed a bit more of the mat after I took this picture). I cut a section of 16ga galvanized steel to fit, and secured it with self-taping screws (added a couple more after the picture). I might switch to rivets for a cleaner look...not sure. Now I'm debating/researching whether a roll-on bedliner will stick to the galvanized steel the way it is, of if I would need to prep is any particular way.
Anyway, I know these pics aren't the greatest....hard place to really get a picture, but you get the idea.
   / A tale of two 5yd dump trucks.... #44
Nice floor repair.
   / A tale of two 5yd dump trucks.... #45
If your worried about it sticking to galvanized metal, you can wipe it down with a sponge soaked in regular vinigar, let it sry, and then coat.
That's a thought. I've been researching painting over galvanizing and it seems to be a mixed bag. I was thinking of trying an etching primer, then the bedliner, and if it doesn't work, I'm not really out anything. It's a small area so even if I have to sand it, prime it and then do the bedliner it won't take long. The question then becomes whether the metal is better protected left the way it is. I guess I'll run it for a while and see how it is.
   / A tale of two 5yd dump trucks.... #48
One thing we do in our sheet metal shop is get some rustolium galvanized gray spray paint. It is supposed to be at a paint but we use it for a primer. Sanding will make it to thin
   / A tale of two 5yd dump trucks.... #49
My guess is if left alone it will outlast the truck around it.
Chris
Yeah, I definitely don't want to make it any thinner.
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
LIGHT TOWER (A56857)
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
