Small Dozer under 10,000 lbs ... do they exist?
/ Small Dozer under 10,000 lbs ... do they exist? #41
/ Small Dozer under 10,000 lbs ... do they exist? #42
Right ... I get it guys . What I'm saying is that if I pick up a small dozer for grading jobs, is it feasible to use it for a small pond? Considering it's on my property and no time limit exists...
Absolutely...it won't be fast, but it'll do it.
/ Small Dozer under 10,000 lbs ... do they exist? #43
That is not going to happen. A d3 weighs close to double what that skid steer weighs. Doing any serious earth moving a d3 will eat that skid steers lunch.
d3 doesn't weigh 20,000 lb a tl150 weighs 10,000. I have ran both before and I know what I would choose
/ Small Dozer under 10,000 lbs ... do they exist? #44
I used mine to do most of the cellar hole for my house. I made a ramp and just kept pushing the dirt out of the hole. Once I pushed it out and made a mound. From there I used my loader to put it into my dump truck to move to where wanted. I think the only thing that would be an issue when it comes to making a pond would be time and if you have very large rocks to be moved. However I have moved some pretty big rocks with mine.
/ Small Dozer under 10,000 lbs ... do they exist? #45
To get under the 10k lb goal, I'd suggest that the Komatsu D20/21 are nice machines. Grey market machines, especially the older units, will not have proper ROPS/FOPS which can be a concern. Maybe less of a concern if tinkering on the ranch, but out doing paying jobs without proper safety equipment can be an issue. Some parts are getting difficult on the older grey Komatsu dozers. Many have the wide mud tracks, which aren't the best for most applications. Some are clutch, some are power-shift. That being said, a USA spec D21 with joystick controls is a sweet little machine. I think it would have some advantages over a big tracked skid steer, but be a little less versatile also. I've had D20/21/31 and a D3. The D31 and D3 are really nice machines. I think I can nearly keep up with a D20/21 with a big tracked skid-steer in many applications, so I am not sure it would pay to go with a dozer smaller than a D3 unless you can afford to have that specialized machine hanging around for those perfect jobs.
My son runs dirt moving equipment for a living and they have a JD450 dozer and the largest JD skid-steer plus an excavator. On smaller jobs, the dozer stays home. Bigger jobs and cutting in driveways and such, they often bring the dozer. If they were forced to sell one or the other, they would likely keep the skid-steer.
/ Small Dozer under 10,000 lbs ... do they exist? #46
A D3 weighs 18,000 pounds. Even if the weight was equal steel tracks will push harder than rubber. For real grading work a dozer will eat a SS's lunch. No offense, but you probably are not a good dozer operator. I suck at using a dozer too, but that doesn't make a SS faster. An 18,000 pound dozer VS a 10,000 SS doing grading work is no contest. Now if the contest was to load a dump truck with dirt the SS is a clear winner.
/ Small Dozer under 10,000 lbs ... do they exist? #47
I would look at buying a used dump truck. Around here they are cheaper than a comparable condition F-350 or a 3500 diesel. I'm sure you could find uses for a dump truck, and tow a bigger dozer.
I've also been trying to stay under 26001 GCWR
/ Small Dozer under 10,000 lbs ... do they exist? #49
Go big! :D
My latest purchase...still getting it cleaned up, but a lot of truck for $4K:
/ Small Dozer under 10,000 lbs ... do they exist? #50
Also, I'm seeing multiple model number variations with the Komatsu d 21 units, especially the last character of the model numbers. Being that I am very new to researching these machines, I have no idea what the differences in models actually means. Would anybody be able to give me a quick explanation of the different variations or options that I am seeing with the model number differences?
Have you looked at Ritchie Specs to see if the differences are obvious when you compare the different variations?
Yeah, there are small differences in things like weight, but functionally, I can't tell.
Nice truck !
/ Small Dozer under 10,000 lbs ... do they exist? #52
The Ritchie Specs show a D3 with a 6 way blade to weigh over 30,000 pounds. Most other places show between 14,000-18,000.
/ Small Dozer under 10,000 lbs ... do they exist? #53
D3, from:
Cat | D3K2 Track-Type Tractor | Caterpillar
Weights
Operating Weight – XL 17465.0 lb
Operating Weight – LGP 18442.0 lb
Operating Weight – LGP, 762 mm/30 in 18896.0 lb
Note Specs are for machine equipped with dozer blade, canopy ROPS, back-up alarm, operator, coolant, lubricants and full fuel tank.
OK ... So, comparing a komatsu D21 (under 9k lbs) to a JD 350 (under 11K lbs) .... And then comparing them both to a 8000lb skid steer with dozer blade...
Which, omitting cost, would be the better small dozer for grading (pitch grades for inspection) small properties under 2 acres, and considering I don't want to buy another truck at this point and want to trailer it behind my F450...?
The factors to consider would be efficiency, machine capabilities, and repair/maint ability? Can you still get parts for each?
/ Small Dozer under 10,000 lbs ... do they exist? #55
Nice truck !
Thanks!
This might help (other than the fact that there's really no way to put an 8-9K dozer on a 10K trailer and not be over 10K):
http://www.alaskaexcavators.com/Komatsu_Dozer_Models.htmKOMATSU DOZER MODELS - EXPLAINED - EQUIPMENT DIRECT, INC
The Komatsu D20 and D21 small dozer line is the only light substantial dozer currently manufactured as new by a major equipment company. The weight on these dozers ranges 8,000-9,000 # depending on options. They can be hauled on a 10,000 GVW trailer behind a pickup with a class 4 or 5 hitch. They are an excellent dozer choice for someone who has a homestead type property and wants to put in their own improvements, a remote site work machine capable of building an airstrip, a residential contractor that needs to work around tight spaces or just someone who always wanted a dozer to play with. They will do a lot of work, you just have to take your time. For this size dozer you basically have few purchase choices other than older JD and Case 350 models or the Komatsu. Komatsu company, while not well known in Alaska is a huge construction machinery company with worldwide distribution. They have a huge line of dozers from largest made to smallest and parts are readily available. These are fantastic little bulldozers and we have dozens of testimonials to their use and efficiency. The dozers we obtain for sale come in 2 basic models and track configurations.
There are 2 model numbers that show transmission type.
D20 = direct drive transmission. This is a standard shift, where you operate a foot clutch and shift with a lever mounted on the floor. Very similar to a standard shift truck and same benefits. Simple, long lasting and more power to the running gear. Very durable and idea for remote location use. The 3rd forward speed is very fast for overland travel.
D21 = power shift transmission or hydrostatic. This allows shifting without using a clutch. You still have to shift to change direction and speed, but the lever is mounted on the side by armrest. There is still a clutch if you need it for close in work. 2 forward speeds /2 reverse. U pattern with neutral in the center forward. This provides a more open cab design than the direct drive models. Faster operation is one benefit.
There are 2 letter designations after the model number that show track type
A Model = Standard track width. On the factory "A" model the shoes are a 12" single grouser with 5.1 psi ground pressure. Blade width is just over 7'. On the models that we convert the shoes, we install a slightly wider 13.5" single grouser for 4.75 psi ground pressure.
P Model = wide track. On the factory "P" model the shoes are 20" pyramid or swamp type shoes with 3.4 psi ground pressure. Some have grouser bar welded to the top for additional traction. These are an excellent low ground pressure pad and are self cleaning and will run in snow without plugging. They are rough riding on rocky ground, do not provide as much traction as the single grouser shoes and tend to break in hard ground applications. Blade width on the "P" model is 8'-4" and angles to 8'.
We can convert the "P" models to an "A" model by changing out the track shoes to an improved 13.5" single grouser shoe or the factory spec 20" single grouser shoe. The 13.5" shoe increases the ground pressure to 4.75 psi but you have the advantage of increased traction, keep the larger blade of a "P" model and the tracks are more offset from the machine providing a wider stance and more stability. We believe this modification gives you an excellent machine/track combination and is only available from us. We have the shoe plates and bolts in stock to do whatever you prefer.
APPLYING THE ABOVE:
D21P - is a powershift wide track
D20P - is a direct drive wide track
D21A - is a powershift narrow track
D20A - is a direct drive narrow track
The only other model designation is the -5, -6 or -7
Models ending in -5 are pre 1985
Models ending in -6 are 1985-1992
Models ending in -7 are 1992 or newer
There are also some -7 models produced after 1997 that have a single lever blade control and the 2 speed in the directional joystick
The -7 models are different in that they have the latest refinements. The most significant is the option of having a single lever (or joystick) steering control. They are also quieter, have full engine side covers and turn off with the key. The -7 models are quicker and are typically the high end contractor models.
All can be outfitted with a Roll Over Protection System canopy to replace the fiberglass rain canopy. We stock all steel canopies. (ROPS INFO).
Click here to download the Komatsu D21-7 brochure
Click here for operation and maintenance tips
THE D31 IS THE LARGER BROTHER OF THE D21- Weighing in at close to 16,000# there are no direct drive D31 models, all are powershift. The "P" models are a 24" wide pad with 9' blade, the "A" models are a standard pad approx 13" and 7.5' blade. They are all powershift and the D31-18 models are lever steer, the D31-20 are typically single lever joystick steering. We can convert the "P" and "A" models to 16" track width if desired.
EXAMPLES BELOW OF DOZER MODELS
/ Small Dozer under 10,000 lbs ... do they exist? #56
I haven't said anything about a D3.
Thanks!
APPLYING THE ABOVE:
Awesome, thx
/ Small Dozer under 10,000 lbs ... do they exist? #58
With an F450, which is an awesome towing rig, staying under 26001 GCWR makes most of the F450's capacity wasted. You could easily haul a 25,900 GVWR tandem dually gooseneck and comfortably put 16k on the deck and be under your axle or GVWR limits. But your gross combined would be near 40k, you would have to be tagged for that I'd assume (I am not up on Michigan DOT rules, just guessing), but that isn't so hard and it sure opens up the possibilities. Just a thought.
/ Small Dozer under 10,000 lbs ... do they exist? #59
That would require a Class A CDL. If the trailer is over 10K, and the combined is over 26K, there's no way around it.
From Michigan Secretary of State:
Who Needs a CDL?
Any Michigan resident who intends to operate the following commercial vehicles is required to have a commercial driver license:
Single Vehicles - Having a gross vehicle weight rating (GVWR)* of 26,001 pounds or more.
Combination Vehicles - Towing a trailer or other vehicles with a GVWR of 10,001 pounds or more when the gross combination weight rating (GCWR)** is 26,001 pounds or more.
Vehicles:
Designed to transport 16 or more people (including the driver)
Carrying hazardous materials in amounts requiring placarding
*Gross Vehicle Weight Rating (GVWR) is the recommended maximum total weight of the vehicle and load as designated by the vehicle manufacturer. The GVWR label is usually found on the driver side door post of the power unit and on the front left side of the trailer. The GVWR should not be confused with the elected gross vehicle weight (GVW) which is declared by the vehicle owner for registration purposes.
**Gross Combination Weight Rating (GCWR) means the value specified by the manufacturer as the maximum loaded weight of a combination vehicle. In the absence of a label, the GCWR can be calculated by adding the GVWR of the power unit to the GVWR of the vehicle(s) or trailer(s) being towed.
/ Small Dozer under 10,000 lbs ... do they exist? #60
I agree, but it isn't that big of a deal to get a Class A CDL. If you have an F450 and a lot of equipment, it's nice to legally be able to haul heavier loads. I can put my Takeuchi TL130 track loader and my TL125 mini-excavator, both at the same time, on my tandem dually gooseneck behind my Dodge 3500 dually and haul them to a job legally. If I tried to stay under 10k on trailer weight, I'd probably not even be able to haul just the TL130 legally as it weighs a little over 8k as equipped and a light duty 10k trailer would probably weigh over 2000 lbs. A small trailer is just very limiting.
I certainly understand the concept of wanting to stay under the CDL threshold, stay out of the scales, avoid the medical certificate, etc. It is a hassle no doubt.
iDrive TDS-2010H...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
Case 1083 20ft Corn Head (A61307)
Case 1083 20ft...
John Deere 6300 (A60462)
John Deere 6300...
