Best way to support rear of trailer....
   / Best way to support rear of trailer.... #11
i've always used block as well couple 6x6s under the rear of the trailer done. i carry them with me anyway. "best" will always be subjective
   / Best way to support rear of trailer.... #12
The best way is to use attached spring assist stand up ramps that have the supports on them. They are also the easiest short of a drop/tilt deck trailer.
   / Best way to support rear of trailer.... #13
I just use a set of $10 HF jack stands. I set them 2" lower than the trailer when empty but tight when loaded so the don't get binded up.
Chris
I'll be using this method with my new trailer. Even though mine has adjustable feet on the fold-up ramps...once the front tires of the vehicle/equipment pass from the ramp to the tail end of the trailer, the feet on the ramps are useless, and the trailer starts to lift the tow vehicle.
   / Best way to support rear of trailer.... #14
[video]http://www.nueratrailerparts.com/images/Product/medium/Bulldog-Side-Wind-Swivel-Jack-2k-18-440-8.jpg[/video]
A couple of these have served me well. Some folks consider them too slow?
I've considered those as well...
I think I'm going to either do this or a drop leg jack. Until I get them mounted I'm going to use the 4x6's.
   / Best way to support rear of trailer.... #16
If the feet on the ramps are adjusted properly and the ramps are rigidly mounted to the trailer you should not have any problems even once the front tires of the vehicle/equipment pass from the ramp to the tail end of the trailer.
   / Best way to support rear of trailer.... #17
Jack stands. Cheaper quicker and you can use them other places.
   / Best way to support rear of trailer.... #18
Same here. Mine have holes for making fast large adjustments, then the crank for final adjustment. These were added by PJ trailer manufacturing. Excellent for my use.
I also use mine to jack the trailer off the ground when not going to be used for a good while. That keeps most of the crawling insects off.
   / Best way to support rear of trailer.... #19
You can get the same thing but with pins instead of crank, which is better for this application, since fine adjustment and lifting aren't needed. Just drop and stick in a pin, no cranking.
   / Best way to support rear of trailer.... #20
So you put down the pinned jack and then put a load on the trailer. How do you get it off?
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56438)
Dual Tailwheel...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
