Trailer Sizes/Style recomnedations for 40hp tractor
   / Trailer Sizes/Style recomnedations for 40hp tractor #1
fontainr
vermont
TBD
I'm in the process of buying a tractor, about 40-45hp and will also need a trailer. I most likely will be moving it with a brush hog or snowblower attached. What length is good, should i get folding ramps or hidden. I was thinking the folding might get in the way if I hang over back. How about width, I'm seeing 7' and 8.5'?
   / Trailer Sizes/Style recomnedations for 40hp tractor #2
   / Trailer Sizes/Style recomnedations for 40hp tractor #3
18 or preferably 20'. Also I like slide in ramps- you can hang the tail wheel of a bush hog off the trailer if needed.
Will
   / Trailer Sizes/Style recomnedations for 40hp tractor #4
This is the trailer that I use: Standard Landscape Utility Trailer 8000 GVWR by Kaufman Trailers
It's great for big jobs like you describe but I eventually got a 5x8 trailer that I use for all kind of little jobs because it's so much easier to pull around the highway and the little hills on my property. The 18' trailer drags on pretty much anything that isn't the street.
However, for carrying the tractor it does the job without complaint. Also, I like having the sides for the occasional big load. We used it when we moved houses, I used it for a big trip to the dump, etc. A flat bed wouldn't let me tie things in like a model with rails does.
   / Trailer Sizes/Style recomnedations for 40hp tractor #5
Welcome to TBN................
I'd guess a minimum of a 20' trailer probably rated at 10-12K with slide in ramps and 82" between the fenders would haul a tractor like you're looking for. You didn't mention getting a loader on your tractor so might get away with an 18'er without one.
I use a 22' 14K PJ full tilt bed trailer. I also have a 16' dump trailer. Either will haul my tractor or most anything else I need to haul.
   / Trailer Sizes/Style recomnedations for 40hp tractor #6
Im surprised at all the recommendations for slide-in ramps. Never used them but always figured they'd be a PIA to pull out and no support for rear of the trailer when loading. Not so?
   / Trailer Sizes/Style recomnedations for 40hp tractor #7
Slide in ramps suck for loading equipment. You couldn't give them to me. Get the heavier duty stand up ramps with the "leg" to help support the rear of the trailer or you will likely have to carry wood blocks around to keep the rear of your truck on the ground by supporting the tail of the trailer.
Op, can you measure the tractor with an implement on? Are you considering a loader? I think very few people go to big on a trailer but many go to small because the load just fits and can't be adjusted for correct weights.
I will be purchasing a tractor with loader.
   / Trailer Sizes/Style recomnedations for 40hp tractor #9
That's not an easy question to answer. First, what are you pulling it with? Bumper pull or gooseneck? I expect your tractor and implements could easily exceed 7000 lbs so weight is a big factor. With the FEL, and a bushhog attached, the length will be more than you think. Measure it first, then add some.
The very best is a gooseneck deck over, with a 20 foot deck and a 5 foot dovetail, with flip up ramps. With two 7000 axles. That will do anything you need. Personally, I would definitely get a deck over. And simple flip up ramps. And if possible, a gooseneck. To me any bumper pull that will haul a 40 horse, with a FEL, loaded tires, a rotary cutter, will be at its limit. It goes back to doing your homework. The length, weight, maximum width (of the widest implement you could ever foresee having), and the rating of both the trailer and your truck all need to be accounted for.
My tractor with a grapple and rotary cutter is long! I have to pull forward with my FEL up to allow the ramps to fold back up flat. But then I can back up to center the weight and get my FEL down flat. It's not a problem
But a trailer is rarely too long, but often too short!
Sent from my iPad using TractorByNet
   / Trailer Sizes/Style recomnedations for 40hp tractor #10
By the way, that's not normally how I transport my rotary cutter, so you guys don't rag me about that. I usually have it connected to the three point. I was just quickly moving it a very short distance and didn't bother to hook it up. This was the only picture I had handy. I know that's not the ideal way to load.
Bear Compound Bow (A57453)
Bear Compound Bow...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
Utility Cart (A59228)
2024 Yakta YXR120 Zero Turn Lawnmower (A57453)
2024 Yakta YXR120...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
