Trailer Sizes/Style recomnedations for 40hp tractor
   / Trailer Sizes/Style recomnedations for 40hp tractor #1
fontainr
vermont
TBD
I'm in the process of buying a tractor, about 40-45hp and will also need a trailer. I most likely will be moving it with a brush hog or snowblower attached. What length is good, should i get folding ramps or hidden. I was thinking the folding might get in the way if I hang over back. How about width, I'm seeing 7' and 8.5'?
   / Trailer Sizes/Style recomnedations for 40hp tractor #2
   / Trailer Sizes/Style recomnedations for 40hp tractor #3
18 or preferably 20'. Also I like slide in ramps- you can hang the tail wheel of a bush hog off the trailer if needed.
Will
   / Trailer Sizes/Style recomnedations for 40hp tractor #4
This is the trailer that I use: Standard Landscape Utility Trailer 8000 GVWR by Kaufman Trailers
It's great for big jobs like you describe but I eventually got a 5x8 trailer that I use for all kind of little jobs because it's so much easier to pull around the highway and the little hills on my property. The 18' trailer drags on pretty much anything that isn't the street.
However, for carrying the tractor it does the job without complaint. Also, I like having the sides for the occasional big load. We used it when we moved houses, I used it for a big trip to the dump, etc. A flat bed wouldn't let me tie things in like a model with rails does.
   / Trailer Sizes/Style recomnedations for 40hp tractor #5
Welcome to TBN................
I'd guess a minimum of a 20' trailer probably rated at 10-12K with slide in ramps and 82" between the fenders would haul a tractor like you're looking for. You didn't mention getting a loader on your tractor so might get away with an 18'er without one.
I use a 22' 14K PJ full tilt bed trailer. I also have a 16' dump trailer. Either will haul my tractor or most anything else I need to haul.
   / Trailer Sizes/Style recomnedations for 40hp tractor #6
Im surprised at all the recommendations for slide-in ramps. Never used them but always figured they'd be a PIA to pull out and no support for rear of the trailer when loading. Not so?
   / Trailer Sizes/Style recomnedations for 40hp tractor #7
Slide in ramps suck for loading equipment. You couldn't give them to me. Get the heavier duty stand up ramps with the "leg" to help support the rear of the trailer or you will likely have to carry wood blocks around to keep the rear of your truck on the ground by supporting the tail of the trailer.
Op, can you measure the tractor with an implement on? Are you considering a loader? I think very few people go to big on a trailer but many go to small because the load just fits and can't be adjusted for correct weights.
I will be purchasing a tractor with loader.
   / Trailer Sizes/Style recomnedations for 40hp tractor #9
That's not an easy question to answer. First, what are you pulling it with? Bumper pull or gooseneck? I expect your tractor and implements could easily exceed 7000 lbs so weight is a big factor. With the FEL, and a bushhog attached, the length will be more than you think. Measure it first, then add some.
The very best is a gooseneck deck over, with a 20 foot deck and a 5 foot dovetail, with flip up ramps. With two 7000 axles. That will do anything you need. Personally, I would definitely get a deck over. And simple flip up ramps. And if possible, a gooseneck. To me any bumper pull that will haul a 40 horse, with a FEL, loaded tires, a rotary cutter, will be at its limit. It goes back to doing your homework. The length, weight, maximum width (of the widest implement you could ever foresee having), and the rating of both the trailer and your truck all need to be accounted for.
My tractor with a grapple and rotary cutter is long! I have to pull forward with my FEL up to allow the ramps to fold back up flat. But then I can back up to center the weight and get my FEL down flat. It's not a problem
But a trailer is rarely too long, but often too short!
Sent from my iPad using TractorByNet
   / Trailer Sizes/Style recomnedations for 40hp tractor #10
By the way, that's not normally how I transport my rotary cutter, so you guys don't rag me about that. I usually have it connected to the three point. I was just quickly moving it a very short distance and didn't bother to hook it up. This was the only picture I had handy. I know that's not the ideal way to load.
   / Trailer Sizes/Style recomnedations for 40hp tractor #11
I agree. We just got our first gooseneck flatbed, I wouldn't go back to BP. GN's do have the issue of cutting tight on sharp bends. Our driveway has 2 sharp turns, I'm wanting to widen those by about 1 foot. We have some particular requirements that drove us to a tilt bed, but if hauling only a tractor I'd be OK with dovetail & ramps.
   / Trailer Sizes/Style recomnedations for 40hp tractor #12
This is a 50HP tractor on a 16+2 BP Hudson equipment trailer.
This is a 23HP tractor with a Box Blade on the same trailer when I bought the package.
Notice the extra room.
IF you get sliding ramps get some support. I like my folding ramps.
Get plenty of stake pockets. My equipment trailer only has 4.
Make sure you've got enough width. When I bought my trailer in '09 (it came with the tractor) 80" was plenty wide. In 2014 I had to reset my tractor rear tires to squeeze the new to me M4700 tractor between the fenders.
But also consider where you are going to haul it. My trailer barely fits in my suburban driveway.
   / Trailer Sizes/Style recomnedations for 40hp tractor #13
This is a 50HP tractor on a 16+2 BP Hudson equipment trailer. <img src="http://www.tractorbynet.com/forums/files/trailers-transportation/442267-trailer-sizes-style-recomnedations-40hp-20140427_103025-jpg"/> This is a 23HP tractor with a Box Blade on the same trailer when I bought the package. <img src="http://www.tractorbynet.com/forums/files/trailers-transportation/442268-trailer-sizes-style-recomnedations-40hp-tractor-n-trailer9x6-jpg"/> Notice the extra room. IF you get sliding ramps get some support. I like my folding ramps. Get plenty of stake pockets. My equipment trailer only has 4. Make sure you've got enough width. When I bought my trailer in '09 (it came with the tractor) 80" was plenty wide. In 2014 I had to reset my tractor rear tires to squeeze the new to me M4700 tractor between the fenders. But also consider where you are going to haul it. My trailer barely fits in my suburban driveway.
That shows that the 16 +2 isn't big enough if he has a rotary cutter attached. It's amazing how long a tractor, FEL and a bush hog can get. Even more with a grapple. Often I also want to make one trip. I'll throw on a box blade as well. Get a 25 footer if your truck and budget will handle it .
   / Trailer Sizes/Style recomnedations for 40hp tractor #14
Here's what i use for my 55 hp with loader and Brush hog, it tilts so no ramps needed. 20 foot x 82" no extra room at 20 foot. I realize my tractor is a little larger than most 40-45hp tractors but it shows just how fast you can run out of space...
It works well for my uses and being a fifth wheel and having a low center of gravity it sure pulls nice.
actually here is a picture of my 40 hp pto ford 3000 on the trailer to-still not much extra room...although i did get an 18 hp riding mower parked in front of the ford.
lots of great options out there good Luck
   / Trailer Sizes/Style recomnedations for 40hp tractor #15
The stand up ramps also help you see where empty trailer is when backing up.
   / Trailer Sizes/Style recomnedations for 40hp tractor #16
I agree, that's why I showed my M4700 squeezed onto an 18' trailer.
However he needs to be careful on how he wants to play the CDL weight game.
Will the OP's truck be rated to haul a 25 footer (usually 14K or greater)?
Will he be going out of Vermont and have to deal with other states enforcement and rules?
Bigger is not always better.
   / Trailer Sizes/Style recomnedations for 40hp tractor #17
I would look into the Hudson bros trailer HSE. Or there deck over trailer for what you are wanting to haul
This trailer will be only for the occasional move, 60 miles one way. I have a 2015 F150 4x4 crew 6.5ft bed w/ 3.5 eco and hope this will pull like Ford claims....
   / Trailer Sizes/Style recomnedations for 40hp tractor #19
I'm not familiar with the tow ratings of your truck . I imagine it will be at its upper limits. Saw this trailer locally and I like the style if your truck could handle it
   / Trailer Sizes/Style recomnedations for 40hp tractor #20
You'll need to check the towing specs in your truck owners manual to see what your max trailer capacity is. A friend of mine has the same truck in a 2014 and the way his is equipped he can tow 8K.
A 40HP tractor w/loader, trailer, and an implement or two will be close to that weight.
He does claim his current truck with the V6 ECO seems more powerful than his previous truck which had the 5.4 V8.
2014 Nissan Murano SUV (A59231)
2014 Nissan Murano...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2020 John Deere 1025R MFWD Compact Tractor (A56438)
2020 John Deere...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2025 Ariens IKON 42 42in Zero Turn Commercial Mower (A59228)
2025 Ariens IKON...
