Any Electricians out there?
   / Any Electricians out there? #41
Probably the last owner tried to lick his fingers and trouble shoot electric.
Hey! Some of us did that and are still alive. Had to lick twice to detect 120V. Worked hot all the time. 480V phase to phase felt kinda like 120V to ground. Had to make sure it was finger to finger on the SAME hand, NOT opposite where it passed through the torso. DON''T do any of these procedures today, use the safety procedures available. Talk walking iron? I walked steel construction hundreds of feet in the air with NO harness, NO safety whatsoever. Guys died and it was shrugged off. Picked your fall at every step and never fell because you had to be alert. Some did not, God rest their soul. DON'T do this today, use the safety procedures available.
Probably the last owner tried to lick his fingers and trouble shoot electric. Let it dry out another 5 months or so. It will fix itself.
No one has ever lived here but me; I had the shop built about 15 years ago and it was wired by a licensed electrician. The plugs look like the receptacle marked "grounded", except they are metal boxes without the red button.
I have changed my mind; I have decided to check out the problem myself. My ignorance and the public shaming is simply too much to bear.
   / Any Electricians out there? #43
..and devote some time to basic personal finance. Like why making the minimum credit card payment on a $50 dollar pair of jeans at 20% interest makes the purchase price hundreds of dollars for pants that are worth $5 (resale) the moment you walk out the store.
+1 :thumbsup::thumbsup::thumbsup:
   / Any Electricians out there? #44
Before spending any money hiring an electrician, just look at all of the dead outlets and see if one of them looks different then the others. The GFCI outlet has it's own breaker built into it kind of like the breaker box, but instead of just tripping when you exceed the amount of current limited by the breaker, or when grounded out, the GFCI will trip when there is any disturbance in the current on the line. They trip all the time, some more then others, and all you have to to is put the button in at the outlet to reset it.
They used to just be used in kitchens and bathrooms because they provide an additional level of safety around water.
Now they are being used all over a house. Outdoors too. I probably replace half a dozen of them a year for clients since they do go bad a lot more frequently then a regular outlet. I rarely replace bad outlets. If you do not find an outlet with the buttons on it anywhere, and you looked real good, odds are very good that it's the breaker. Outlets and wires rarely go bad. Breakers and GFCI outlets do a lot more often.
If you find that there is a GFCI outlets and nothing happens after you push one of the buttons, then try the other button, then that's a good indication that it's bad. Sometimes you need something more then just your finger to reset the button on a GFCI outlet. I usually use a pencil, or a small screwdriver, or the tip of my pocket knife. Anything that is smaller then my finger so it will go in all the way.
One button is to reset it, the other is to test it, or turn it off.
   / Any Electricians out there? #45
Do you have a multimeter? If not, for your purposes a $10 -$20 meter like this would do the job.
http://m.sears.com/craftsman-digita...qOww-umKQPs72-EPyimg8q9bGTczYZm7tEaAoQF8P8HAQ
The particular model doesn't matter much. Go to your local hardware store or Home Depot and pick one.
Don't be intimidated by it like I was for years whenever a friend would get his out. Just read the directions on how to check for AC volts.
Start at the sub panel. Then go up or downstream depending on what you discover.
   / Any Electricians out there? #46
Not public shaming! Just trying to encourage you to jump off the diving board! You of course will have to work "live" in the trouble shooting phase...just be careful with the probes on your multi-meter. If you find the offending problem, I'd suggest you go "dark" (take a flashlight). Just curious...from your previous posts it sounds like you have a sub-panel in the shop. If so I think you are supposed to have a shut-off at that point (should be labeled "main"). That will "kill" the panel although you will still have live power from the house to that shut-off device. To be perfectly safe kill it at the house end. Also someone previously mentioned a GFCI. Typical installation will be to insert one of those somewhere in the circuit (depending on where you want to start GFCI protection) and then wire off that for all downstream connections where you want GFCI protection (you only need one GFCI outlet to provide "downstream" protection to other outlets (that will look like any other outlet). elec testing.png That little plug-in tester will have a button on it to test any downstream connection for ground fault. Plug it anywhere in the chain and you should trip the GFCI outlet. Pretty handy device. Good luck!
   / Any Electricians out there? #47
Let us know if you want specifics on how to use the multimeter, should you go that route.
I would first probe a known good outlet (maybe in the house) to see how to use it and what reading you get when it's on a working circuit.
   / Any Electricians out there? #49
Well, It looks like he is going to take his first steps down "handyman road". Work smart, work safe, and come back here for advice if you need it. I salute you.:thumbsup:
   / Any Electricians out there? #50
:thumbsup:
2001 JUSTIN 14 MOTORCYCLE TRAILER (A53843)
2001 JUSTIN 14...
2014 CATERPILLAR 324EL EXCAVATOR (A52705)
2014 CATERPILLAR...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A51406)
2012 INTERNATIONAL...
Electric Mobility Scooter (A51694)
Electric Mobility...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A53473)
3-Point Hitch Root...
