How well do shelter logic hold up in heavy snow areas?
   / How well do shelter logic hold up in heavy snow areas? #61
I have a 12' x 10' x 24' ShelterLogic. I purchased it for 1/2 price at Canadian Tire. It is a round model with a 8'4" roll up door opening. I have to leave the door up in the winter, as the zipper would never work due to snow and ice. I mounted the whole shed on 12" milled hemlock in order to give me the extra 12" I required to get my LS 7010 out of the weather. I used 5" lag bolts to attach the shelter to the logs, thank God I did because with the front open it is a wind catcher. I will be glad when I get the garage finished because it makes me nervous leaving the tractor in the shelter when the wind is blowing hard. A small vent is not sufficient to release all the air that comes in, most of the air escapes under the sides. They do have to be well vented to help reduce the condensation which forms. Not a bad tent for the $600 or $700 I paid for it but you can't beat a permanent structure for sure.
   / How well do shelter logic hold up in heavy snow areas? #62
Answer to JAMES RE SHELKTER TECH DIAGONAL BRACES PM
Hi James: I would be glad to provide more info, but cannot do a photo, sorry, no digital camera.
Here is what I did: I purchased 4 12-Foot lengths of half inch calvanized thin wall conduit and eight galvanized steel fence clamps tro fit the upright members of my shelter (I think they were two inches in dia) which had one tab to accept a 1/4-20x 3/8ths galv stove bolt and eight 1/4-elastic stop nuts. I crushed about two inches of both ends of each conduit in a vise to flatten it, then drilled a 5/16ths hole in each flattened end. I chose the vertical pipe of the shelter uprights nearest the two entry doors and fastened a clamp to the top of each just below the horizontal longitudinal pipe. Then I fastened a clamp to the lower end of the two vertical pipes of the shelter that were next in line behind to the door pipe, just below the longitudinal pipe that runs across the bottom..
Then I placed a conduit between each pair of clamps, adjusted and tightened the bolts placing each conduit in tension, not compression. Easy, cheap and effective! (This will prevent lateral, but not horizontal Sway) I am not sure that is what happened to your shelter. Horizontal sway is difficult to brace, but IF your vertical post are all positioned on a solid LEVEL base, that should not happen in the first place.
Your PM did not allow me to copy your TBN handle, so I could not reply via PM. Good Luck , James
   / How well do shelter logic hold up in heavy snow areas? #63
Between my neighbour and I we have had four pipeframe buildings in the past ten years. My first one from Princess Auto had a great frame, but the roof seam let go the second year. Two cheaper Shelter Logic buildings have had the frame fail during overnight snowfall dumps. The last one is a different make but the frame is starting to twist after one heavy dump last year. We have kept them as snow free as possible.
I hope to build a series of wood trusses next spring, set them on stick walls and cover the whole thing with "lifetime tarps" These are old bill board sign covers that run about 14'x60' and sell for about $40 around here. I have one covering a 14'x20' deck roof (2"x10" on 16" center) that is on its 3rd winter. The snow stays there and builds up to about 20" each winter with no ill effects on the tarp.
I figure I can get my studs and plates from a local mill, and build the trusses myself. I need to wind up with a building that I can drive the tractor into, then lift and move with the FEL.
   / How well do shelter logic hold up in heavy snow areas? #64
   / How well do shelter logic hold up in heavy snow areas? #65
Shelter tech is NOT the same as Shelter Logic.. As you have discovered. Shelter Tech are four times as well made, and cost 4 tomes as much. You get what you pay for
   / How well do shelter logic hold up in heavy snow areas? #66
Unless you don't have much snow/wind, buying heavy materials to start with is usually the better way to go.
Having watched this thread for a while (and having a friend go through a few light weight versions), I'm wondering if pouring concrete into the tubes would help. If the up-in-the-air connectors can handle the weight, it would make the tubes hard to bend, and add ballast to the whole frame.
Obviously more so a summer project......
(Edit - has anybody priced out a DIY project using ABS DWV pipe ?).
Rgds, D.
   / How well do shelter logic hold up in heavy snow areas? #67
I have noticed that Shelter Logic has now increased the size of their "tubes" on some product's,
a little over 2" now and of course, their more expensive.
   / How well do shelter logic hold up in heavy snow areas? #68
Larger OD looks better. If wall thickness didn't go up, don't expect much of a gain in strength.
Budget-wise, that's why I got thinking of concrete - cheap way to add strength.
Rgds, D.
   / How well do shelter logic hold up in heavy snow areas? #69
Rgds, D.
I've had mine bolted to "railway track beams" the real kind, very heavy.
Never had an issue with it moving, whatsoever.
I have the 12x10 high x 24 long,, going on it's fifth year (round type).
   / How well do shelter logic hold up in heavy snow areas? #70
With all respect to the OP, Shelter Tech has TWO grades of shelter available.(ONE is the Standard grade, the SECOND is the CANADIAN grade). The Canadian grade has larger dia tubes with thicker walls and a thicker type of plastic cover. I have the Canadian grade, plus I have 20 extra duck-foot stakes ( one for every vertical; and extra wind straps 4 vs 2. I also have the ratchet type of lower attachment tighteners all along the bottom edge.)
When I built it, I used fine grade crusher dust two feet thick for the base and patio blocks for each vertical post, (everything dead level in two directions and well compacted) before installation. The cover was tightened to the max with the ratchets. These extra steps are why the shelter has withstood six winters, two hurricanes and amazing snow loads. I do not have to push the snow off, ever and wind does not make it sway, because I added braces (see Earlier posts) to prevent the structure from any longitudinal flexing. The whole job cost me 3,500 dollars taxes in. It was quite pricey, yes, but it is still standing. Cheaper jobs, even from Shelter Tech will collapse under heavy snow loads.
I cannot emphasize enough: If the structure gets off plumb or level, or if is allowed to flex in the wind, the weight will eventually break the tubes at stress points. It Must be dead plumb and square...and well secured and braced..just like a house is. The frame of the shelter will only give max strength if everything is lined up, is plumb, and stays that way. Overkill is way better than hoping.
Shelter Logic does not have the heavy grade tubing nor the heavy grade cover material and it cannot withstand heavy weather. It is a waste of time and money..and it endangers you and everything inside it, if it collapses, which it will..take a look around and check it out for yourself.. This is one thing you cannot do on the cheap!
Filling the tubes with concrete will make them stiffer, but would be very hard to do and then how would you get the screws into it. Also, it will not strengthen the cover, So I would not even consider doing that. Putting up a big frame is already hard enough to do.
Buy the best stuff, do it right and You WILL be satisfied, just as I am....after six horrid winters here in the Maritimes.
.. (no I do not have any financial interest in the company Shelter Tech), but they are a New Brunswick company and they have a six-month backlog of orders currently. Because they do it right. That is all good. It gives we NB guys pride.
JIX
   / How well do shelter logic hold up in heavy snow areas? #71
I had thought of putting up one of these "instant garages", then spray-foaming the inside to make it stiff...thinking about it further, I figured I might as well build a real building and have done with it!
   / How well do shelter logic hold up in heavy snow areas? #72
Boys, When I screw something up, I do it in spades;
PLEASE BE ADVISED that in all of my posts on this subject I have used the name SHELTER TECH.
The CORRECT NAME IS COVER TECH. ( see covertech.com)
I apologize if you are mislead. sorry...its what I get for having "old timers" memory
JIX
   / How well do shelter logic hold up in heavy snow areas? #73
Hi MacGregor;
aye, me laddie buck. I cannae quarrel wi ye on that, if you got the shekels!
   / How well do shelter logic hold up in heavy snow areas? #74
JIX
Thank's, "old timer" lol
I had a hard time looking up shelter tech.
   / How well do shelter logic hold up in heavy snow areas? #75
I can't believe nobody mentioned WeatherPort Shelter Systems. They manufacture in Colorado so you know they can take a snow load. Because they are local, (I live in Delta) I bought a carport from them around 6 years ago. It has held up in the most extreme snow loads I've ever seen. Looking them up you see they have lots of camps, tents, and other structures located in Alaska. If you want a long term solution, they are a great answer... just expect to pay.
   / How well do shelter logic hold up in heavy snow areas? #76
Recycle the framework:thumbsup: Once your tarp wears out, cover the framework with inexpensive galvanized sheet metal roofing material like this guy did, I did the same thing except without adding the wood and put the sheet metal on lengthwise. I just sheet metal screwed the roof sheeting into the steel tubing. The fabric wore out after 3 years, the metal has been up for another 6 more years so far.
   / How well do shelter logic hold up in heavy snow areas? #77
Looks like the floor drain might be clogged:)
   / How well do shelter logic hold up in heavy snow areas? #78
LOL, my "Shelter Logic" is the rounded top kind, 24 feet long, the tarp lasted 5 years,:thumbsup: then I bought the same set-up again, doubled the frame with the new to the old and put the new tarp on top. I plan on putting a steel tin roof and plywood for the sides later on.
   / How well do shelter logic hold up in heavy snow areas? #79
I also hard sided the front, didn't like the zipper door and made wood doors for the front.
   / How well do shelter logic hold up in heavy snow areas? #80
I put up a 10ft x 20ft x 10ft set up as a shelter for a small car. Unfortunately, our area is prone to sudden strong wind gusts and the shelter lifted off the ground and carried some 30 yds and then came back to earth and bent all the framing and tore the fabric beyond repair. This shelter had been bolted to long railway ties and concete blocks - the ground was too hard to drive in proper anchors.
If you do erect such a building don't leave it without adequate ground anchors or it might just end up airborne.
I ended up building an enclosed carport and am happy with they way it has turned and the way it deals with the heavy snow we get over the winter.
I'am setting up a 12x20 round top shelter logic and had planned to set cinder blocks in the ground under each footing and use the screw in ground anchors on the ends. After reading your post I'm having second thoughts.
What type concrete blocks did you use.
John Deere 4520 (A60462)
John Deere 4520...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
