Max28 and cold Weather
   / Max28 and cold Weather #31
Mike,
Are you running off road fuel? I have found that the Mitsubishi diesels, in the Mahindra tractors, do not particularly like off road fuel. I have convinced some of my customers to switch to highway fuel and it helped the problem.
There is no difference between off-road and highway diesel except for dye. I think you guys are imagining things!
Mike,
Low sulfur straight from the Shell station
   / Max28 and cold Weather #33
It seems like the glow plug function does not match the description in the owners manual, this is what I've found as well but I only did the test once. I may pull mine out of the garage this weekend and do the same test after letting it sit outside overnight.
I don't suppose you have tried calling Mahindra tech support to see if they have seen similar behavior?
So Like once before i let it sit 2 minutes with the ignition to run position, without GP light.
Then I turn the key to crank and it starts right up?
I did a bit of plowing cleanup with BB to charge up battery and warm motor and called it quits for tonight.
This is very weird.
So Friday, I'll try just one GP cycle and let it sit with ignition on for 2 minutes, then crank over engine to see what happens.
   / Max28 and cold Weather #34
13 Years of experience, with Mahindra tractors has proved this to me.
   / Max28 and cold Weather #35
Is there a summer and winter version of diesel (additives?)? I believe I've seen this mentioned a few times on this board. The place where I get diesel says no difference, but I'm not convinced he knows what he pumps.
My own 2216 can be stubborn in cold weather. I've got one of these Kat's 1153 Handi Heat 200 Watt Magnetic Heater that I stick on the crankcase and I think helps a bit.
   / Max28 and cold Weather #36
I was just too windy and got back late last night so I tried it tonight. 19 F and no wind.
I cycled the glow plugs 3-4 times, then crank for 5 seconds then repeated the 3 X cycle GP's two more more times. No Start.
This is very weird.
Can you confirm glow plugs on with a test light or meter,key on, no GP light?
   / Max28 and cold Weather #37
You need to clean the ground connection were it meets the frame from the battery. Clean the connector and the frame itself with sand cloth
   / Max28 and cold Weather #38
I hate to break it to you, but you really are imagining things (unless Mahindras can't tolerate red dye). There have been quite a few topics on TBN where this has been discussed, and Google has many links too. It's all the same stuff.
I'll try calling Mahindra if I get a break at work from manning tech support!
   / Max28 and cold Weather #40
that's what he's saying:
Wolverine Quick Attach Blade (A50515)
Wolverine Quick...
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
2020 John Deere 160G Excavator (A47384)
2020 John Deere...
Miller Welder (A51691)
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
