Does the f250 Super Duty make the f350 obsolete?
   / Does the f250 Super Duty make the f350 obsolete? #1
ultrarunner
Epic Contributor
SF Bay Area-Ca Olympia WA Salzburg Austria
Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
At one time there were significant differences between the F100, F250 and F350 trucks.
When Ford truck shopping it really seems the F350 is almost redundant?
The F150 is in it's own class with specs that supercede older heavier models.
The Super Duty F250 is a significant difference from the F150...
The F350 not so much over the F250
The next big jump over the F250 is the F450
Am I missing something?
   / Does the f250 Super Duty make the f350 obsolete? #2
The only way I would see the F350 going away is if the SD F250 abilities overlay the F450's. There may be less demand but Ford would give up market share if there were a gap between the F250 and F450. Chevy 3500 would step in and market the gap.
   / Does the f250 Super Duty make the f350 obsolete? #3
To me there is no comparison. For example my F350 has a payload rating of 3,900# while a comparable best case F250 work of be 2,500#
Chris
I was looking at towing specs and if anything it seemed a wash until the f450
We did go f250 and had it derated to 9900... seems crossing the 10k rating brings other things into play.
Not to mention the weight fees are quite substantial...
So the big difference is in payload... same engine/transmission and cab/box
   / Does the f250 Super Duty make the f350 obsolete? #5
Not much difference in the F-250 and the 350 SRW but there is a huge difference between the 250 and the 350 DRW. They don't offer a 250 DRW.
   / Does the f250 Super Duty make the f350 obsolete? #6
With 1/2 ton trucks approaching 3/4 capacities (in gas versions at least) it almost makes the 3/4 seem obsolete. For the minimal cost to upgrade from 250 to 350 srw you get a whole lot more truck. The problem is if you live in an area that hates 3/4 and 1 ton trucks and loves taxing them then you might be more inclined to stick with the 3/4 ton truck. A lot of people in my area are having to take overall cost AND weight into consideration because our local government is taxing trucks silly. I just paid $280 in taxes on a 10 year old 1/2 truck if that tells you anything. A new 3/4 truck with an msrp of say $50,000 would be INSANE in taxes around here and no they don't depreciate fast either (your tax bill might be $20-30) cheaper next year if you're lucky.
My 1985 3/4 chevrolet is still $200 a year for tags... and the governor wants to add a $100 across the board because vehicles are more fuel efficient and gas tax revenue is dropping.
The new truck left the Kentucky plant last week... it arrived locally Friday afternoon... Dealer says maybe Wednesday for delivery as they won't get to it for prep till Wednesday morning.
Good or bad... you can be sure I will post about it... my brother has owned two pickups... almost 40 model years apart... both Ford F250 with 4wd and now his son will have one in the middle with the 96.
   / Does the f250 Super Duty make the f350 obsolete? #8
Hey can ya plow with one of those???
I would imagine so... have heard plowing snow is the most common.
   / Does the f250 Super Duty make the f350 obsolete? #10
Yup, I used my F350 DRW to plow about 1/8 mile of Highway 72 near Muscle Shoals, Alabama when the Uhaul car dolly (w/car) lost a wheel back to the axle stub. It was a shallow furrow until I noticed it was pulling and got it to plow the side of the road.
   / Does the f250 Super Duty make the f350 obsolete? #11
F250 still have their place. I'd buy a 6.2 gasser to get a long bed extended or crew cab and a solid front axle.
Don't need the extra of the 350.
   / Does the f250 Super Duty make the f350 obsolete? #12
F250 still have their place. I'd buy a 6.2 gasser to get a long bed extended or crew cab and a solid front axle. Don't need the extra of the 350.
I looked into the 6.2 until I found out it has 16 spark plugs.
   / Does the f250 Super Duty make the f350 obsolete? #14
Still cheaper than diesel. Up until recently the 5.7 hemi had dual plugs too.
And the plugs on the Hemi need to be changed every 30K miles.
   / Does the f250 Super Duty make the f350 obsolete? #16
To me the F350 SRW is a no brainier. It's only a $600 option over a comparable F250.
Chris
This is the other reason that got me thinking why have both when the cost is nearly the same as is the body, bed, powerplant...
How much better can the brakes and axles be for $600?
Now if the real difference is springs... $600 would cover beefier ones.
   / Does the f250 Super Duty make the f350 obsolete? #18
It may have changed but the big difference between the 250 and 350 was 2 things:
1. 350 had a 4" riser block on the rear axle vs 2" on the 250
2. The weight rating on the door sticker
Now there are a million different setups of these trucks with all kinds of various spring packages, etc, but the real difference is one you have heard several here say: the ratings. That is a double-edged sword as it affects both what you can tow, as well as places you can/can't go (and often your taxes). You cross that 10k threshold, and it hurts some applications. We have a short section of freeway here where it is 9k max GVWR on it. Can't even drive my 250 on it as it is 9400 GVWR. Those are the main reasons for the different models. Otherwise they are identical.
   / Does the f250 Super Duty make the f350 obsolete? #19
Not on the 6.4 hemi.I owned a 2011 F250 super crew and could not stand they way the rear end sagged when I hooked up my trailer.
One mile from me we have a similar 9k max freeway with the only exception being buses...
However the Highway Patrol will not cite "Pickups"
They can and do cite the same pickup with duals, a service body or stake flatbed.... very subjective.
Wacker Neuson AR14H (A60462)
Wacker Neuson...
2013 Ford F-150 Pickup Truck (A59230)
2013 Ford F-150...
40' CONTAINER (A52706)
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
2011 KOMATSU D65PX-16 CRAWLER DOZER (A60429)
2011 KOMATSU...
