sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 15,727
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have used synthetic motor oil for many years and am growing concerned that the pending versions due in 2017 will reduce engine protection enough that I might be better off switching back to a non-synthetic "dino" oil. Most of the newest oil categories, close as I can figure, only reduce the levels of the ZDDP that is necessary to protect various part of the valve train. The change is because of newer DPF tractors and by that virtue will force all older tractor models into the new oil use mode that I don't want to be in.
Now, I know oils are supposedly back engineered but I'm not sure I believe that ZDDP amounts can be further reduced without eventually causing some engine harm, especially in older engines. If I switch back to dino oils, I can get versions that have not reduced the ZDDP levels and are more than adequate for my engines.
My equipment is used mostly in the summer, gets short interval oil changes and is post 2003 up to 2014. No DPF or DEF stuff. So I really don't need synthetic; my only purpose was for reduction of startup wear.
What do others think? Switch or fight?
