Gas Fireplace Question
   / Gas Fireplace Question #1
Dougryan
Webster, NY
Cub Cadet 3206
Hi,
I'm going to have a gas fireplace installed soon. I'm doing the framing for the install (inside corner of the family room) and a pro will do the actual unit install with gas and electric hook ups.
To prep for the install, all I need to do is build the platform that the unit will sit on. The installer needs the space to put in the gas, electric, and vent through the wall. Once that is done, I will frame up the enclosure, have it all inspected, then do the finish work.
Even though this is a 'zero clearance' unit, there is still plenty of clearance required. Especially above the unit where the coaxial vent pipe comes out and does the 90 degree bend to the exterior wall. I expect a lot of dead space where no combustible materials may be used. This is probably because the vent pipe and space above the firebox will get hot.
So here's my question... Can I take advantage of that heat be leaving an opening at the top of my enclosure (and possible a small vent at the bottom to allow a convection)?
Seems like two good outcomes. 1 - A bit of extra heat in the room. 2 - Lets the heat escape the enclosed cavity.
Thoughts?
Thanks,
Doug
   / Gas Fireplace Question #2
What type of enclosure? is this for a fireplace insert, or a free standing unit. We have a Jotuel gas stove, replaced a wood unit.
   / Gas Fireplace Question #3
My two new inserts already have vents/venting at the top and bottom of the unit to take advantage of the convection. Check with your supplier and see if you can find a unit that includes venting.
SimS
   / Gas Fireplace Question #4
Most gas fireplaces (and wood units too) have an open cavity around the main inner firebox, with vents open to the room on top and bottom. Room Air will go in the bottom and come out the top heated up.
The outer shell doesn't get very hot, so there wouldn't be much heat there in your framed cavity, plus without an air path to help it flow, I don't think there would be a huge benefit. And I bet some part of fire code requires it to be sealed/isolated from the outer room so that possible stray flames can't get into the framing. At least with wood units, many of the clearance and material specs are about protecting the home's framing from flames in the main fire box that could possibly escape the main front opening. Gas is a different beast of course, but often the codes are the same.
Hi,
To be specific, it is the Enviro Q1 gas fireplace (not the model that would be inserted into an existing masonry fireplace). The model I am buying will get built into a stick framed 'bump in' structure in the corner of a room. Here is a link to the product page Enviro | Products | Gas | Q1 Gas Fireplace
Thanks,
Doug
   / Gas Fireplace Question #6
I looked at the PDF for specs/dimensions, and it has the same types of external clearances as a wood-burner, so my guess is that fire code won't allow you to have openings into the wall framing above the fireplace. Again, this has more to do with flames escaping out the front of the unit than it does the clearance around the fireplace inside the wall. Fire code is real conservative when it comes to openings in framed structures within 4-5 feet of a fireplace, wood or gas.
Hi,
From the Napoleon website...
Direct vent is a term used to describe a specifically designed fireplace that performs differently from the traditionally vented fireplace which use a chimney. This type of fireplace has a completely sealed combustion chamber which allows it to vent directly out a side wall of the home. One of the benefits of this type of design is that it must draw air necessary for combustion from the outside since the sealed combustion chamber does not allow air to be drawn in from around the fireplace. The co-axial vent system has the exhaust pipe within the air intake pipe which protects any surrounding combustible material from the high temperature of the flue gases as well as preheating the outside air prior to it being introduced to the combustion process.
So there should be no issue with flames escaping the fire box.
Doug
   / Gas Fireplace Question #8
Doug, I know all that, but it doesn't have anything to do with fire code, clearances, etc. The gas fireplace at our last house still had code requirements for non-combustable materials on the face around the fireplace for a certain distance from the opening. As far as fire code is concerned, it's still a "flame" inside the walls/framework of a home, and they don't really differentiate whether it's direct vent or not -- that's more about airflow and gasses.
If you look at the drawings for your fireplace at that link you gave, it has face clearance requirements just like any other gas or wood fireplace. I suspect if you look at building/fire code for your location, it's going to forbid openings into the wall framing within a certain radius of the fireplace (it's normally in the 5-10' range, but I don't know the exact numbers for your situation). There are similar requirements that prevent stoves and fireplaces from being located near HVAC ducting and other types of "chases" within a home. Anything that provides a possible path into the guts of the framing is not allowed.
Here is a picture of a 'bump in' framed with a fireplace installed. I drew a couple of parallelograms where I was thinking about putting my vents... Just an example showing how warm air could get out of the cavity above the fireplace by letting cool air in at the bottom.
Doug
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
159120 (A60430)
159120 (A60430)
Hydraulic Liftgate (A59230)
Hydraulic Liftgate...
Enmark Z Spray (A53316)
Enmark Z Spray...
