Any good, safer replacement for a wire wheel on a bench grinder?
   / Any good, safer replacement for a wire wheel on a bench grinder? #11
I use my HD stand model the same as you do, with a knotted wire wheel on one side and the standard wire wheel on the other side. I do get a few thrown wires from the standard type wheel, which one can't get totally away from, but not many. And none from the knotted. I think I got my wheels from Eastwood some years ago.
   / Any good, safer replacement for a wire wheel on a bench grinder? #12
I bought an 8" Dewalt wheel and it has not thrown any wires that I've noticed on my bench grinder. It's balance was horrible and vibrated badly so I made a offset washer that bolts next to it in the arbor and can be rotated to balance. It now runs very smooth and I've been super happy with the quality otherwise.
   / Any good, safer replacement for a wire wheel on a bench grinder? #13
If you ever see the wire brushes with the brass coated steel bristles, those are actually made with wire that was rejected for use in tires, as a way to use up that wire making "something". They were never designed for any actual purpose other than to sell cheap.
Best advice I ever got was to buy name brand brushes with thicker wire. I like really stiff brushes, so was told to try a "knotted" (twisted) brush. That was 10 years ago, and I am still on the same one. It's replacement has been sitting on the shelf behind it the whole time, I bought 2. I was also told that they clean better if you flip them over now and then. It is too stiff for cleaning threads, though, so I usually use a hand brush for that.
   / Any good, safer replacement for a wire wheel on a bench grinder? #14
I keep an embarrassingly large collection of rotary (and hand) wire brushes around for various uses; regular, soft, stiff, knotted, straight, cup, and in maybe a dozen different sizes. They are so useful for so many things, especially when refurbishing old stuff; rust and paint removal and thread cleaning are tops, but a soft one at high rpm is very good for polishing. I recently did a slightly pitted rifle barrel and it almost exactly duplicated the original factory finish/polish and even left a little bluing. The tiny Dremel ones are terrific for cleaning and smoothing internal gun parts.
The better quality ones are definitely worth the extra $, but for light use, even Harbor Freight ones are ok. I was recently surprised to find that their collection of Dremel brushes were actually capable of more than one or two uses if kept to a lower rpm.
5 Piece Stainless Steel Wheel and Brush Set
They have them in both stainless and brass.
   / Any good, safer replacement for a wire wheel on a bench grinder? #15
3M makes some good non metallic abrasive wheels that are alot safer and clean rusty steel, some we use for removing paint, rust.
   / Any good, safer replacement for a wire wheel on a bench grinder? #16
I've used both the cheaper wire wheels and the higher quality ones and hands down the higher quality ones won out over the cheaper ones in every way. No where near the amount of wires thrown and they lasted multiple times longer than the cheap ones and in the long run they ended up being much cheaper to use.
Regardless of what wire wheel you chose please use eye protection. It takes just that one errant wire to ruin your day...and maybe longer.
   / Any good, safer replacement for a wire wheel on a bench grinder? #17
At a place I worked in the past we had the need to clean hundreds of large diameter bolts.
I located a tool which you chuck in a large, low speed drill which looks like a hole saw but
has stiff wire bristles mounted on the inside which contact and clean the threads. Don't
remember the name off hand but I'll look it up Monday at work and add the info here for
anyone looking in the future. They make a brush for cleaning nut threads too.
Not cheap but very safe to use and they last for a few hundred bolts. We were cleaning
1-1/4" x 7-1/2" SS and Monel studs.
For small diameter nuts try using a copper fitting cleaning brush. Cut the handle off and
use it in your cordless drill at low RPM. A 1/2" copper brush would work for 5/8" nuts and
maybe for 1/2" but would be a tight fit.
Here it is, found it faster than I thought I could.
shipman-ind.com
   / Any good, safer replacement for a wire wheel on a bench grinder? #18
Bead blast cabinet with beads, fine walnut shells, fine corn cob or plastic blast media.
I love my blast cabinet, so much faster than a wire wheel & gets most of the crevices too. Running beads in there now which leave a bit of a satin finish. Great finish for painting on, not that it's relevant generally for nuts & bolts.
   / Any good, safer replacement for a wire wheel on a bench grinder? #19
Skip the wheel and soak those small parts in Evapo-Rust....parts come out with zero rust. It's not caustic so you can get it on your hands, it doesn't smell terrible, and it's biodegradable, so you can have some go down the drain without causing any problems. The nice thing is you can reuse it...I just filter it with a rag/show towel when I put it back in the jug.
   / Any good, safer replacement for a wire wheel on a bench grinder? #20
Here you go,
Amazon.com: Evapo-Rust ER12 The Original Super Safe Rust Remover - 1 Gallon: Automotive
2018 CASE 340RT TRACKED TRACTOR (A60430)
2018 CASE 340RT...
2017 Versatille 260 (A60462)
2017 Versatille...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
