Tig Welding Failure, what am I doing wrong
   / Tig Welding Failure, what am I doing wrong #11
Since you are trying to weld thin steel,,, and you have some copper laying around,
why not try putting the copper under the steel as a heat sink.
Although a lot larger, this was the same problem.
I wanted to abrasion resistant weld the edge of some tiller tines.
I clamped some copper under the tiller tine, and stick welded (1/8" rod)
I would avoid trying to weld copper until you master welding steel.
Copper can be VERY tricky to weld, especially if you do not have the machine completely figured out.
   / Tig Welding Failure, what am I doing wrong #12
As a beginner, You may want to drop back to 1/16 tungsten. Mainly for the thinner stuff. without pulse or Hz adjustment you will see a little less trouble with the smaller tungsten. Then practice..
   / Tig Welding Failure, what am I doing wrong #13
Yup, I hung up my scratch tig kit today. I reversed the Polarity, and while it spread out the heat, once the copper got hot it still just vaporized no matter how I moved. It is clear to me that the 20 amps my meter reads on my welder is more like 50.... There is probably some way to check this...
Anyway, I did tig on thicker metal, and it works pretty sweet. Slow as snot but I get it and I get how cool it could be.
The downside is that I am 100 in the hole on a scratch start tig system I will not use. The upside is that I see a nice tig rig in my future.... Tigging is pretty cool, I don't want to say easy but I get how it is an attractive way to weld.
If you have a DC tong meter or borrow one, You can clamp in on your ground and it will tell you true amp output.
   / Tig Welding Failure, what am I doing wrong #14
Well, been doing a bit of reading. Going to try reverse polarity today. see how that works.
But in the end I think it is my wonderful and very powerful Everlast 200. I always felt that bad boy was hot, but with Shields comments I am now confirming that that little box is a great stick welder.
Reversing the polarity results on melting the tungsten like it is a stick rod. If you reversed polarity and it didn't melt the tungsten, then you may have some polarity problems with your machine. I think your machine is running much more amps than indicated, 20 amps should allow you to weld any sheetmetal without burning thru. I wouldn't use a #6 cup with 3/32 tungsten, get at least a #8 or even a #10 so you get better gas coverage without the gas blowing out like an arc gouger. When outside welding even in still air I always ran about 20 CFM or more on my TIG torch but I was not buying the gas. Also look at getting a Gas Lens and cup rather than the standard collet body. The same collets will work with the gas lens but you need a different cup.
I will pick up a smaller tungsten and a different cup. and yes, the gas is sounds like a jet engine sometimes.
As for running reverse polarity, it did ball up the tungstend for sure but it provided a different arc. Still too strong
And I will continue with scratch start. I am just bummed that this did not work for thin stuff.
question to all, why do you tig thicker metals? What does this process provide that is not in MIG? I am assuming a cleanliness in the weld and its slow pace allows for a higher quality weld but....
   / Tig Welding Failure, what am I doing wrong #16
I only Tig weld fairly thin, or small objects. I Tig weld most aluminum, but I do have a spool gun for thicker aluminum. For large projects I use my Mig / wire feeder.
   / Tig Welding Failure, what am I doing wrong #17
Did you put the 3/8" bolt in the nut when you welded that nut in to avoid any warpage of the threads or just do it free with no problems?
   / Tig Welding Failure, what am I doing wrong #18
I Tig welded the nut just for an example. I also Mig welded one. Placing a bolt in the nut before welding is the way to go:thumbsup:, also could run a tap through the nut too.
   / Tig Welding Failure, what am I doing wrong #19
Sheild Arc; your welds are always a joy to look at.
   / Tig Welding Failure, what am I doing wrong #20
Thank you very much Egon! But I'm just a hobby welder.;)
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
TANK MANIFOLD (A55745)
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
2022 KOMATSU PC360LC-11 EXCAVATOR (A60429)
2022 KOMATSU...
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
BOX BLADE (A58214)
BOX BLADE (A58214)
