Anyone have a 17 super duty?
/ Anyone have a 17 super duty? #121
We'll need pics of course!!! :)
Well, obviously I'm not the only one that appreciates truck ****! :) I tell my wife she should be happy my **** comes in the form of trucks instead of women. :laughing:
/ Anyone have a 17 super duty? #122
This thread has really dropped my jaw lmfao, I paid less for my house than two of those trucks are worth lol
Yep. No way would I pay that kinda of $$ for any vehicle. Wait a couple of years and buy one for way less $$.
Has ford finally built an engine that will stay together without any mods. ?
I'm not a ford guy ,but have been told that some were built with aluminum head bolts, (and some other stuff). They said if you replace all this factory stuff (he said 3 K) it's a good motor.
My son is a FF/medic. They have ford rescue trucks. He says when they have their rescue truck in the shop for engine repairs. the cab has to be removed to access the engine. WTH ?
/ Anyone have a 17 super duty? #123
Welcome to 2003. That was the 6.0L you are referring to. It came out in 2003 (late 2002 as a 2003 model) and was not built by Ford. The 6.9L, 7.3L, 6.0L, and 6.4L were International/Navistar engines, and were not built by Ford. The 6.7L Ford has offered since the 2011 model year is Ford designed and built, and has been nearly bullet proof. Very few problems for the 6.7L.
That is true, for major repairs, the cab has to come off the truck. That is really the only way to get to the engine because it is so cramped under the hood. Thankfully, Ford has designed everything for quick-release of the cab to make it easier. A lot of techs have mentioned that they remove the cab at times even when the procedure doesn't require it simply because it is easier to reach everything that way. It's really no bid deal now.
/ Anyone have a 17 super duty? #124
Well, she showed up to the dealer over the weekend. :cool2::cool2::cool2: First pic:
/ Anyone have a 17 super duty? #126
Very nice! I'm jealous. It's too pretty to be a truck.
The most "truck use" it gets is hauling our kids, our fifth wheel, my deer to the processor, and minor household use, so it's OK if it's pretty. :)
/ Anyone have a 17 super duty? #127
I'll have to ask him what the price is to remove the cab. He told me the cost . I don't remember, but best I remember it was expensive . I don't know what model truck they have right now. I'm quite sure it is the newer model with a ford engine. Not an old one with the Navistar engine. Quite a few fire departments around here went with a different brand truck within the last couple of years because they were having engine problems with the fords.
/ Anyone have a 17 super duty? #128
Unfortunately, the issues with the 6.0 and 6.4 turned a lot of folks off from Ford trucks. Thankfully, those days are in the past, but people don't forget that truck they had that was nothing but a problem.
/ Anyone have a 17 super duty? #129
they were talking about one of the engines having problems related to aluminum head bolts :confused3:
Which engine was that ?
/ Anyone have a 17 super duty? #130
It wasn't the aluminum head bolts, it was the fact the engine didn't have enough head bolts. One part of 'bullet proofing' the 6.0 includes the replacement of the head studs with new ones.
Head gasket failure became a common cause of repair. "Especially on the 6.0L, there was a design flaw-not enough head bolts. The head bolts pass through an aluminum carrier and cast-iron head, and you just don't get the clamping force," Dugas noted. This can be addressed by replacing the torque-to-limit head bolts with head studs that offer better clamping power.
From Banks Power: http://bankspower.com/magazines/show/617-ford-power-stroke-6.0l-part-1-what-fails-and-why
/ Anyone have a 17 super duty? #131
My Son has removed at least 30 for various repairs. Says it takes him an hour. Then he stands by the vehicle and works. The manufacturers that should be talked about are those that don't offer this convenience. :)
/ Anyone have a 17 super duty? #132
The engine upgrades can cost $2K for parts.
The cab removal is insignificant.
/ Anyone have a 17 super duty? #133
None.
/ Anyone have a 17 super duty? #135
It would be significant if it were 2K to remove it. I'll have to ask him what they were/are paying for this.
/ Anyone have a 17 super duty? #136
I have a 2007 F450 with the 6.0L International. It's been fully bulletproof'ed (not cheap) among other updates. Once completed, it's a very reliable engine capable of great power.
You'll pay somewhere around $4500 for parts and labor (depending on where you go) and i believe the custom shop that did mine only charged about 3 hours for cab removal & reinstallation. So... Probably somewhere less than $300 of the labor went into the cab lift.
Regarding the head bolts... The problem was two-fold. There were not enough, and they used TTY (Torque To Yield) bolts that would stretch to a measured tightness. The problem came when you'd build too much pressure on the heads (usually due to Oil Cooler and EGR issues stemming from silicates in the coolant) and stretching the head bolts. Once stretched, you'd have head gasket issues.
The fix was to use hardened head studs (along with removing the EGR system, replacing oil cooler, after flushing and replacing the gold coolant with green ELC).
Those are the major areas of attention. Yes it's an expensive repair. But once done, it's a good engine. You can also pick them up cheap because of the past issues.
/ Anyone have a 17 super duty? #137
Agreed! If it weren't for the safety requirements, I think we would likely see a tilting front end on pickups like the big rigs have.
Yep, color me jealous..... ;)
I'm a bit jealous too. My wife and daughter actually got to sit in it yesterday and I haven't even seen it yet! Signing papers today, then bringing it home tomorrow after the bedliner is sprayed in. Just in time to take it to STL for my daughter's field trip on Thursday. Gotta get those 1k (or close at least) break-in miles so we can go camping! :)
/ Anyone have a 17 super duty? #138
I think we are making two different points.
Just ballparking numbers here.
1. Doing 6.0L upgrades using cab removal method requires 20hrs labor.
2. Doing 6.0L engine upgrades without removing cab requires 25 hrs labor.
Which is mos cost effective method? Removal actually speeds up the process and saves costs. :)
/ Anyone have a 17 super duty? #139
And the mechanic is a lot less cranky because everything is easier to get to and his knuckles are left intact! :)
/ Anyone have a 17 super duty? #140
My dad has a fleet of 6.0 trucks. Every winter the trucks get fluid maintenance, with one of the fluids that gets replaced is the coolant. Because the coolant never got to the point of the silicates falling out of suspension and clogging up the oil cooler, we never had EGR issues. Those tucks never had any problems that other 6.0 that were neglected had.
You will not find a tougher bottom end on any diesel out there. That is one area international did a find job on, because they were originally built as a bus engine.
I am a huge fan of 6.0 diesel trucks, but one has to understand them to own them.
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2020 HAMM H7I COMPACT LINE SMOOTH DRUM ROLLER (A59823)
2020 HAMM H7I...
3 BOTTOM TURN PLOW (A60430)
3 BOTTOM TURN PLOW...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel Fork...
2025 CATERPILLAR 305CR EXCAVATOR (A60429)
2025 CATERPILLAR...
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
