Brush b gone....
   / Brush b gone....
Sure do appreciate all the suggestions, I'm going to try to find the Gordon's at our local tractor Sullpy
Gotta get on top of it PDQ as the electric fence is getting goofy.
B. John
   / Brush b gone.... #13
No personal experience but this stuff claims to be a year long brush killer. Gordon's Barrier Year-Long Vegetation Killer Concentrate, 1 gal. - For Life Out Here
I just tried this for the first time this year and went with the higher level mixture on their label. It took forever for it to show any signs of working. I think it was more then two weeks before stuff started turning brown. Eventually it did kill everything I spray, but now, a month later, weeds are growing back.
I rate it no better then any generic round up, just a lot slower and more expensive.
   / Brush b gone.... #14
I have never used Gordon's "weed killer"!
I use Gordon's BRUSH KILLER, and for brush only!
Gordon's weed killer & brush killer are different chemical formulations.
The Gordon's brush killer works great,(for killing brush) and mixing it with diesel instead of water, seems to work even better.
(You did not hear that from me!)
   / Brush b gone.... #15
Thanks for the input on this product! I will take it off my want list when I get ready to spray my fence line.
   / Brush b gone....
Very interesting opposite results using the Gordon's product. As of today, I haven't shopped for the product due to other seasonal chores but wondering if a dash of diesel fuel added to the sprayer mix would ramp up the effectness of the product by providing a bit more staying power on the unwanted vegetation.
I would rather not go the chemical route but dancing with a mechanical brush cutter along several hundred feet of fence row is not exactly my idea of romance either.
B. John
   / Brush b gone.... #17
This stuff is good kills everything!.
   / Brush b gone.... #18
I use what SCDEERSLAYER uses / 2 oz of each per gal.
   / Brush b gone....
Looked this product up on the 'web'. Five star rating with 52 positive customer reviews so, from the comfort of my own kitchen placed an on line order this morning.
I will keep y'all posted on the results so stay tuned......
   / Brush b gone.... #20
I've been using Triclopyr (Garlon 4 is a common trade name) for poison oak. Triclopyr is specific to broadleaf plants, is not too toxic to people and critters and does not last too long in the soil. I first tried some retail package stuff but it was not all that effective. I found some papers from the UC extension on poison oak removal and they recommend a 2-5% solution of Triclopyr applied to the leaves. The retail package stuff was 8%, so with their label recommended few ounces/gallon the concentration's way too low. I bought a gallon of 62% Triclopyr and some surfactant (and a 4 gallon backpack sprayer- we have a TON of poison oak). I've tried spraying at 1% triclopyr and 2%. Both work but with 1% you need to get all the leaves. If you miss some the plant will live even while most of the leaves die, and it will form new leaves. 2% is better at killing the plant. Either way it takes a while, that's the nature of Triclopyr. It'd be great if there was a smoking hole half an hour after application but since nothing works very well on poison oak I'll take dead and crispy in a month.
The UC documents also recommend basal application of a 20% solution in oil (diesel or vegetable). You spray 18" of the stem. I'm going to try that on some of it, where I can get to the stems.
All herbicides have seasons and applications where they work better or worse depending on what you're spraying. It's worth while doing the research so you're getting the most effect for your expense and effort. It only took me a few minutes to find what I was looking for.
Kubota RTV X900 (A53317)
Kubota RTV X900...
1608 (A57192)
1608 (A57192)
2022 Ford F-450 Liftmoore 5000W Crane Service Truck (A59230)
2022 Ford F-450...
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
500BBL WHEELED...
