ZD1511 72" REAR DISCHARGE INFO & BLADE OVERLAP
   / ZD1511 72" REAR DISCHARGE INFO & BLADE OVERLAP #31
Went to a dealer today & drooled all over a ZD1511 72" Rear Discharge unit
Man I like it but just ain't sure on tier4 DPF BS.
Then get the 1211. Ours should be in at the end of the week supposedly.
Brett
$4 Grand MORE for 6 extra hp.
Us farmers & shade tree guys are clueless when tier4 electronics starts acting up.
   / ZD1511 72" REAR DISCHARGE INFO & BLADE OVERLAP #33
The 1211 is the same mower but with 24.8 hp and no tier 4. You can get a 72" rear discharge. That's why we're getting it is to keep from having emissions on a lawn mower. Biggest difference is a real nice suspension seat vs the air ride on the 1511
Brett
I just couldn't make myself pull the trigger today on the ZD1511 "Tier4 LawnMower".
I always buy the bigger engine on EVERYTHING I buy, BUT the Tier4 is pushing me towards the ZD1211 24hp.
The ZD1211-72 frt & rear axle widths looks the same as the ZD1511-72 as far as I could tell ?
Both has 61.4" wheelbase.
   / ZD1511 72" REAR DISCHARGE INFO & BLADE OVERLAP #35
I couldn't find much difference between the two besides air ride seat, more hp but chocked down by emission stuff. I don't think adjusting the governor to 3200 would hurt anything if your low on power but the one I ran wasn't lacking at all. They are awesome and will mow full out if the ground will allow it
Brett
I turned the blades to 3&9 o clock & visually looked at them from frt of deck, today in the showroom.
I'd estimate 3/4-7/8" blade overlap. Not near as much as I'd like to see :-(
When tips of blades get worn off from grit & pebbles at 18k rpm, you have VERY LITTLE blade overlap.
IDK why mower mfg's don't have 1.5+" blade overlap like Bush Hog RFM do.
They could move center shaft housing out more & use longer blades.
   / ZD1511 72" REAR DISCHARGE INFO & BLADE OVERLAP #37
Didn't you notice how thick those blades were? What did you think about that?
Brett
Brett
I'd "guess" the blades were 1/4" thick idk.
I did notice the rear discharge blades didn't have as big of air lift wings like the side discharge blades.
The rear discharge deck also has a narrowed discharge opening so the opening isn't 72" wide and the grass gets double cut on the Rear discharge the way it's designed ...
The ZD1#11 72" rear discharge deck is open all the way across the back with Three Separate Rubber Deflector flaps partially hanging down to keep exhausted clippings off engine & transmission.
I really like the way it's designed, as I've been mowing with rear discharge since 2001.
Year: 2019 Make: Ford Model: Escape Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 141,789 Pla... (A56859)
Year: 2019 Make...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
NEW HOLLAND W80C WHEEL LOADER (A52707)
NEW HOLLAND W80C...
2021 JOHN DEERE 648LB GRAPPLE SKIDDER (A52705)
2021 JOHN DEERE...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2019 Dodge Charger Sedan (A55853)
2019 Dodge Charger...
