Shop Air Compressor set up questions?
/ Shop Air Compressor set up questions? #81
Oh .... ok. Good idea on increasing storage capacity.
Hockey puck vibration isolators ...... good idea and cost effective.
Guess I’ll have to stop by one of our local Hockey Pucks R US stores.
/ Shop Air Compressor set up questions? #82
I'd hafta make a couple stops to find pucks here. I'm guessing it'd be an all day event for your Rick. :D
/ Shop Air Compressor set up questions? #83
/ Shop Air Compressor set up questions? #84
I gotta get out more. If I happen to find myself in a Mall I can't figure out why they don't have a Sears or JC Penney's.
/ Shop Air Compressor set up questions? #85
I haven't gotten 'round to "permanently" situating mine yet. It's still on the original shipping blocks it came on back in 1979. IMG_4550.JPG
/ Shop Air Compressor set up questions? #86
Don't worry about it Terry. If it hasn't happened by now it probably isn't important. :)
Back in 79 the skid was made from hard wood... and put together with a little bit of care... in 2017 skids are made with no care, staples and wood sourced from grandmas flower garden. I didn't feel good about lifting the compressor on the skid with my pallet forks, one of the three legs was only on by 1/2"...:eek:
/ Shop Air Compressor set up questions? #88
Sadly true about a LOT of things nowadays....
/ Shop Air Compressor set up questions? #89
"it alive!"....well sorta.
After a expensive trip to a plumbing supply store. I had all I needed to plumb the compressor to the regulator.
There is not a lot of room in my closet, so when I installed the compressor I decided to make it easy for me to change the V-belt and compressor oil. By doing that I made it near impossible to see the pressure gauge.
I use 3/4" brass pipe fitting rated to 1000 psi for everything. The flex hose is rated to 300 psi, and the pressure gauge goes up to 160 psi (i should have got a 250 psi gauge).
my biggest hurdle was the limited space under the compressor for the drain line plumbing.
Dear all compressor manufactures,
Spend an extra 25 cents and make the legs on your compressors taller.... if you expect the end user to drain the tank every day... make it easy!
I didn't have room to install the 1/4" ball valve to the drain port, a buddy saved the day with some fancy fittings. when the weather warms up I'll run the drain line outside.
The compressor still isn't functional yet, since I don't have anything down stream of the regulator yet. I did do the 1hr long break in procedure. and I'm happy to report the noise level in the shop with the compressor running is great. I can carry on a normal conversation 10 feet away. I expect that to get even better when I plumb the intake to out side.
and wow did the oil ever change color after 1 hour of break in! the manual says to change after the 1st 50 hrs, but I think I'll change it a bit sooner.
I'm a bit confused to what oil to use.. the manual says non detergent 30W or 10w30 mobil one.... I suspect this has something to do with operating temp's. I plan on calling campbell hausfeld to get some clarification.
/ Shop Air Compressor set up questions? #93
Maybe 2 hockey pucks under each leg?
/ Shop Air Compressor set up questions? #94
You guys may laugh but I purchased 4 of those Harbor Freight 3 wheeled dolly's and placed them under the skid holding my air compressor. Makes it easier to clean the shop up since I can move it around just a bit to get in the corner of the shop.
/ Shop Air Compressor set up questions? #96
I just use the air compressor to blow the junk out from behind the air compressor.
/ Shop Air Compressor set up questions? #97
so if/when the compressor legs wear in to the hockey pucks, I'll replace them. as stated they are cheap and plentiful.
its not as simple as just adding another hockey puck to raise the compressor another inch... I would need to use a different concrete anchor. I'm already using the longest 3/8" anchor I could find.
its simply something the manufacture could do cheaply that would make a difference.
I fully understand that in the 60gallon and under $1000 compressor market, the two main selling points are CFM and price. I understand small things like drain valves, tie down points and the ability to extend the air intake piping... are just that small things most people don't care about.
/ Shop Air Compressor set up questions? #99
I solved that problem on mine with a timed electric auto drain valve.
SPEEDAIRE Auto Drain Valve,Drain Size 1'/'4",4. gpm - 53DN44'|'53DN44 - Grainger
A pic of mine. I plugged the cord into a $5 power strip and secured it up high for an easy reach. I can let it run at the setting of my choice, or shut it off and on without having to crawl under it.
/ Shop Air Compressor set up questions? #100
^^^I've put in several and I believe money well spent... the oldest is circa 1995 and no issues.
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
(INOP) 2023 TAKEUCHI TL12V2 SKID STEER (A60429)
(INOP) 2023...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
BUNDLE OF 8'-13' CORRUGATED METAL SHEETS (A60432)
BUNDLE OF 8'-13'...
