jeff9366
Super Star Member
- Joined
- Jan 14, 2011
- Messages
- 12,777
- Tractor
- Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
I expect Shuttle Shift costs Kubota substantially less than HST/PLUS. I not an expert on how M7060s are kitted but I can confirm Grand Ls are loaded. There may or may not be same/less deLuxe kit on an M7060.
Both models are heavy-chassis tractors with commensurately strong front axles. You will certainly want liquid filled rear tires, wheels spread wider than normal, but not so wide it restricts movement between trees in your woodland and Three Point Hitch counterbalance is still essential, but with those caveats you need not fear front axle damage and stability will be good.
My last Kubota was a B3300SU, one of the predecessor models to the L2501. With its light weight and powerful Loader I picked up the rear wheels often, even with counterbalance. Decided to buy heavier BEFORE rolling it. Since delivery in January 2013 I have never had the air filled rear R4 tires of L3560 off the ground. My land in Florida is FLAT.
You will still need a chainsaw(s), plenty. While you can pick up felled long trees with a grapple, you cannot maneuver them between growing trees. You can tow large trees and bundles of smaller trees from the rear/center drawbar or an A-frame cross drawbar on the Three Point Hitch. But once towed trees pick up dirt saw chains dull in seconds. When I tow trees destination is the burn pit. I tow long to avoid several chainsaw cuts, every cut a potential hazard.
More tractor weight does not hurt if the budget permits.
Here are a few pictures of my 3,600 pound, bare weight, L3560 Grand L.
