Everlast Welders - Welders and Plasma Cutters by Everlast
   / Everlast Welders - Welders and Plasma Cutters by Everlast #921
What are the welding cable connectors on the PowerArc 200ST ? The product info says standard Dinse 35 connectors. If Dinse 35's exist I can't find them. At first I thought it must be a misprint for Dinse 25 but now I am not sure. I want to build a set of extension cables and have them ready when my welder arrives so it would be good to know what connectors I need to order and if they are special where I can get them. Thanks.
gg
   / Everlast Welders - Welders and Plasma Cutters by Everlast #922
This is how I do it. I cut the female end off the Dinse leads that come with the welder. Then use Tweeco welding lead connectors.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #923
Mark, I'm a beginning welder. I purchased a Lincoln 210 MP as I wanted "One machine for everything" and am learning stick welding with it.
I intend to learn MIG (everyone says it will be much easier) but most of my welding will be repairing farm equipment.
Though I enjoy my current welder, I'm growing tired of moving it between home and the farm. I'm looking for something portable to purchase and leave at the farm, Stick only, no need for MIG down there. I have both 110 and 220 available at the farm, would prefer a small machine that could run off a Honda 2,000i generator in a pinch.
Would you have a recommendation?
Thanks.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #924
Good to know! Thanks
   / Everlast Welders - Welders and Plasma Cutters by Everlast #925
Wait 'til you learn MIG. When you start MIGGIN' you will discover that you can repair lots of things that a stick-welder thinks are not repairable. I started migging on the farm 38 years ago. The MIG was a Miller, in 1980, and it was already several years old. We NEVER stick-welded anything except in the field with the stick welder on the crane truck. The stick welder in the shop just gathered dust. This was a larger farm, 2700acres, so there was LOTS of eqpt.
I still run into folks to this day who think MIG is some kind of newby welding process for beginners, that can't really make a strong weld. It's a classical notion (which I understand) that people "say" for effect, but not reality. Don't knock your MIG. Everything you buy is made with a MIG, manufacturers don't go "classical" they go for production, quality & efficiency and that's MIG.
Here's a drywall screw welded to a broken wire coat hook. Welded with a MIG (on 2 Honda generators). You can't do that with a stick until you have YEARS of experience, and only if there's no MIG nearby.;)
440962d1442468236-welded-wire-coathook-mig-coathook3-jpg
One EU2000i is not feasible period. I ran a MIG from TWO Honda EU2000i generators paired, did LOTS of welding, lots of projects. I tried it on one EU2000i, just to see how low it can go. one Honda 2000 can't run a welder. The generator shuts down quickly then pouts for awhile.
But two EU2000i can. Here's welding with two Hondas (paired) replacing a trailer jack. The Hondas are inverter generators, and when paired they arrange their phases to align properly because they are designed to be paired. With two Hondas you can weld well on the 3/16" thickness setting, but it's not really enough for the 1/4" settings (1/4" is full power for 120v). On the 1/4" settings the generators bog and then overspeed and catch up, but I don't like the start of my weld to be during a "bog". But you can, in a pinch, but you have to be mindful of your weld starts. You can "pair" three Hondas (and more) then it would be good for 1/4" on 120v - but that's 3 starter ropes to pull, and who has three Hondas?
385695d1407474675-millermatic-200-elite-img_8217-jpg
After getting it all done, and doing a real nice job I kicked myself because the tailgate hit the new jack just like it hit the old jack. :mad:
So I cut it out and moved it rearward (and to the side).
   / Everlast Welders - Welders and Plasma Cutters by Everlast #927
Thank you very much for the help. I was starting to wonder if any one knew for sure what the connectors on the PA 200ST were. I saw those but they are Dinse 50 connectors not Dinse 35 connectors. I guess you are saying they are the same thing. Are you saying that the PA 200ST actually has Dinse 50's ???? Pretty confusing when you don't know anything about connectors and no one else calls them 35's. Thanks again that is very helpful.
gg
The difference is the size of the wire cable it will hold. It is a volume measurement of some sort. I still don't understand it. The pins are roughly 1/2" in diameter.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #929
I just called Everlast and they said the backordered 200STs will be arriving this week and might even ship out on Friday (27 April).
   / Everlast Welders - Welders and Plasma Cutters by Everlast #930
Good news - Thanks !!!
gg
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
Root Grapple (A50322)
2007 CATERPILLAR 257B SKID STEER (A51242)
2007 CATERPILLAR...
2002 WACKER RD25 ROLLER (A51222)
2002 WACKER RD25...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
