MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 65,765
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
No, it could make it in mid range by dramatically slowing down to the point of barely moving in mid range, in low range without the loader you could stay at full HST and the PTO RPM would drop to around 400.
I know that. I also know that you are familiar with how to let off the HST pedal to get more response when the machine starts to bog down. I have to do that with my HST machine as well.
What I'm curious about is that I would think that if you had to let off the HST pedal in M range to get it up the hill fully equipped, by just shifting into L range, it should have walked right up the hill fully equipped. By shifting into L it should have increased your effective gearing by about 32%. That's a huge number. Even with the oversized tires, it should have been a significant change in effective gearing switching from M to L. That's the part I'm having a hard time understanding.
On the overall issues, I'm guessing that by putting oversized tires on it, and a mower deck that is probably at the hairy edge of too large for the input PTO HP of 19.5, coupled with your hill slope, the machine is going to be underpowered.
Your engine is rated at 26HP, your PTO is using up to 19.5HP if you load the mower down with air resistance and grass blades, that only leaves you with 6.5 HP to move it up the hill. Add to that the 7% gear reduction of the taller tires.
So much for someone else's assumption that raw machine weight is more important than engine HP. When doing tasks like mowing, engine HP is extremely important, more imortant than machine weight, because it has to be able to spin and keep spinning the mower through varying resistances of wind and grass/brush, while at the same time moving the machine on varying terrain both up and down.
I'm not criticizing your machine or decisions, but it sure is coming acrosss that way in my written text, so please don't take it that way. I'm not the most eloquent writer. I wish we could sit around a fire pit or the garage with some other TBN folks and talk about it with some beverages. My own machine has some shortcomings that I'm happy to pick apart as well.
Good luck with the diagnosis and cure.
