sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 6,123
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
I was wondering since it was a used mower, if the deck had been properly lubed, but you covered that very well in the second video. I would consider looking into a lighter oil in the gearbox, maybe synthetic if Kubota has any lighter oil recommendations. Having just lost a gearbox on a 8 foot Bush Hog brand mower, I wouldn't suggest playing with lighter oils if they aren't on the recommended list. (I didn't).
Remove the belt sometime and spin each of the blades by hand and see if one bearing is tighter than another. That might be part of your HP drain.
Consider looking for a slightly smaller pulley on the bottom of the gearbox. Most pto mowers are rated at 540 and you are turning 580 so you could stand just a little drop in speed of the blades. The difference in blade speed will save some HP, and coupled with what you have already found by removing weight, make your new toy a better fit.
David from jax (where we don't have hills!!)
