Front end goes out again!!!
   / Front end goes out again!!! #1
Phillip w
whiting ks
allis Chalmers 185 and massey ferguson 1531
Well, here we go again. I was picking up rocks with my little massey. Had a pretty good load in the bucket. Was spinning and slid it in 4 wheel drive. POP SNAP POP. Oil running everywhere on left front hub. What a piece of crap. Just rebuilt it about a year ago. This is the 4th time front end has shelled. It is combersome, but got the allis out to finish the job. These little mf are definitely a light and i mean light duty tractor. So sad wgat agco has done to the mf line of equipment.
   / Front end goes out again!!! #2
When it was spinning did you engage 4wd or did you let everything stop and engage it then?
Brett
No, i came to a stop. After the 3rd rebuild agco kind of admitted that the front axles are this Particular model are weak if you are doing much loader work. But a bucket of rocks??? Please.
   / Front end goes out again!!! #4
After the second rebuild and it shelled why not get a whole new front assembly
   / Front end goes out again!!! #5
What kind of ballast are you using and how much weight is it?
Brett
   / Front end goes out again!!! #6
Something isn't right. Front ends ARE NOT that fragile.
   / Front end goes out again!!! #7
Brett
I’m pretty sure his front end is junk. They should survive that with or without ballast.
   / Front end goes out again!!! #8
What load would you suggest is more challenging than rocks?? Maybe molten lead? or Gold?
   / Front end goes out again!!! #9
The ballast unloads the front end. On a tractor that has a known weak front end, I’d be sure to use nearly max ballast when doing FEL work to try and help it along
Brett
   / Front end goes out again!!! #10
Brett
Until you try to back it up hill. Then the front axel drive component have a lot more load than without the ballast.
TURN PLOW (A57192)
TURN PLOW (A57192)
2017 GENIE GTH-844 TELESCOPIC FORKLIFT (A52707)
2017 GENIE GTH-844...
UNUSED FUTURE (100) PIECES OF 12'X3' GALVALUME (A57193)
UNUSED FUTURE...
(APPROX 15) 6" X 2" X 68" TUBING (A57192)
(APPROX 15) 6" X...
Eagle Weathervane (A55853)
Eagle Weathervane...
2019 Ford F-350 XL (A53317)
2019 Ford F-350 XL...
