Front end goes out again!!!
   / Front end goes out again!!! #1
Phillip w
Platinum Member
whiting ks
allis Chalmers 185 and massey ferguson 1531
Well, here we go again. I was picking up rocks with my little massey. Had a pretty good load in the bucket. Was spinning and slid it in 4 wheel drive. POP SNAP POP. Oil running everywhere on left front hub. What a piece of crap. Just rebuilt it about a year ago. This is the 4th time front end has shelled. It is combersome, but got the allis out to finish the job. These little mf are definitely a light and i mean light duty tractor. So sad wgat agco has done to the mf line of equipment.
   / Front end goes out again!!! #2
When it was spinning did you engage 4wd or did you let everything stop and engage it then?
Brett
No, i came to a stop. After the 3rd rebuild agco kind of admitted that the front axles are this Particular model are weak if you are doing much loader work. But a bucket of rocks??? Please.
   / Front end goes out again!!! #4
After the second rebuild and it shelled why not get a whole new front assembly
   / Front end goes out again!!! #5
What kind of ballast are you using and how much weight is it?
Brett
   / Front end goes out again!!! #6
Something isn't right. Front ends ARE NOT that fragile.
   / Front end goes out again!!! #7
Brett
I’m pretty sure his front end is junk. They should survive that with or without ballast.
   / Front end goes out again!!! #8
What load would you suggest is more challenging than rocks?? Maybe molten lead? or Gold?
   / Front end goes out again!!! #9
The ballast unloads the front end. On a tractor that has a known weak front end, I’d be sure to use nearly max ballast when doing FEL work to try and help it along
Brett
   / Front end goes out again!!! #10
Brett
Until you try to back it up hill. Then the front axel drive component have a lot more load than without the ballast.
2012 Ford E-250 Cargo Van (A55852)
2012 Ford E-250...
JCB 300T SKID STEER (A52707)
JCB 300T SKID...
2016 Peterbilt 597 Wet Kit Tri-Axle Day Cab Truck Tractor (A55852)
2016 Peterbilt 597...
2024 John Deere 35 P Excavator (A53485)
2024 John Deere 35...
2005 Dodge Caravan Van (A55853)
2005 Dodge Caravan...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
