Buying Advice 2501 or 3301--Questions, Questions, Questions
   / 2501 or 3301--Questions, Questions, Questions #1
Trailfarmer
Lafayette, IN
Kubota DT245
I'll try to keep this less than novel length:
Looking at L2501 or 3301
Bought almost new B2650 with FEL 18 months ago to replace 40 year old, much loved DT without FEL.
The B has been a good, but not great tractor for me--not as heavy duty as expected and I've been careful with it so as not to tear it up.
Want more lifting power, bigger front tires, and just "more"--
I've read a lot of threads here so am aware of the "emissions issues" and "buy more if you can"
Used the "Build My Kubota" page to compare models
On to the questions--appreciate any an all opinions\thoughts\guidance:
-2501 incentives expire soon(!), anyone have any idea\guesses what the next round of incentives will be?
-Weighted tires vs. ballast box: used to be a tire guy, but research has me leaning toward ballast box. Around here I can get ballast box for much less than getting tires filled (a hopefully one-time cost I know)
-QA bucket vs. standard: Local dealer said QA setup reduces amount of weight tractor can lift by 300lb and QA pallet forks even more so. Now considering standard bucket and bolt on forks Didn't plan to remove bucket often and would hate to lose lifting capacity--want to move dirt, logs, etc regularly. QA setup is also $600 more.
-Prices.....
Called Barlow and 2 nearby dealers
Barlow--600 for delivery unless he has another to my area
Local dealer 1--actually pretty competitive with Barlow, which surprised me
Local dealer 2--supposed to call tomorrow with prices
Local dealers charge tax and Barlow wouldn't, but my state now asks on tax forms about large purchases from out of state and I won't lie about it.
Check Craigslist often and haven't seen anything of interest in last few weeks.
Planning to finance as cash prices aren't a whole lot less--B almost paid for so will roll money from sale of it onto new tractor.
Trying to decide before end of month at this point, but will wait if things don't feel right.
Thanks in advance for the help
   / 2501 or 3301--Questions, Questions, Questions #2
If you think QA forks are a liability to lift capacity you don’t understand what bolting/chaining/clamping forks onto a bucket will do to capacity. It will cripple the capacity. Get the QA bucket and forks. If that won’t lift what you need to lift, buy a bigger tractor and get QA forks and bucket for it.
The QA device might be a $600 option, but it will cost you $1000 or more to sell or trade a loader without it because NOBODY is going to want a loader less QA.
   / 2501 or 3301--Questions, Questions, Questions #3
If you are going to be using the FEL, filled tires and ballast are a must in my humble opinion. I have mine filled and am always having some ballast on and will soon build a good ballast box.
QA for sure as RickB said.
I have a 3301 and love it. If I were to do it again, I might consider even going bigger, though mainly for better FEL power. Being my first tractor I had too high of expectations for the FEL. I know better now and know what it can and can't do and just work around it.
   / 2501 or 3301--Questions, Questions, Questions #4
B2650 has a bare tractor weight of 2,293 pounds. Tractor has deLuxe kit.
L2501/3301 has a bare tractor weight of 2,700 pounds. Relatively Spartan kit.
For most tractor tasks greater chassis weight is more important than tractor horsepower. For novice tractor shoppers the fundamental importance of tractor WEIGHT is difficult to comprehend. In subcompact and compact tractor categories it requires a 50% increase in bare tractor weight before you notice a significant tractor capability increase. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
I suspect you will be dissatisfied with an L2501 or L3301.
Consider a $27,000 L3560, the lightest Kubota Grand L.
L3560 has a bare tractor weight of 3,500 pounds and deLuxe kit in a package only slightly larger than L2501/3301.
Pay once, cry once.
VIDEOS: Kubota Standard L-Series. L251 L331 L391 L471 features and operation. - YouTube
Kubota Standard L Series VS. Grand L Series - YouTube
   / 2501 or 3301--Questions, Questions, Questions #5
Consider an L3560, the lightest Kubota Grand L.
L3560 has a bare tractor weight of 3,500 pounds and deLuxe kit.
Pay once, cry once.
I don’t disagree.
   / 2501 or 3301--Questions, Questions, Questions #6
-QA bucket vs. standard: Local dealer said QA setup reduces amount of weight tractor can lift by 300lb and QA pallet forks even more so. Now considering standard bucket and bolt on forks Didn't plan to remove bucket often and would hate to lose lifting capacity--want to move dirt, logs, etc regularly. QA setup is also $600.
When using clamp on pallet forks the bucket is dead weight, detracting from payload. Bucket 250 pounds to 300 pounds plus forks 100 pounds = 400 pounds.
SSQA pallet forks attach directly to the FEL, eliminating the bucket. Weights vary from 250 to 350 pounds, depending on weight/lift capacity of forks.
Lift capacity of SSQA forks is equal to or greater than clamp on forks.
SSAQ pallet forks have an operator protecting top guard as part of the frame, an important safety feature.
Spend the $600.
These are the 36" length, 309 pound, SSQA Pallet Forks I use on my Kubota L3560:
Construction Attachments, XTreme Duty, Skid Steer, Skidsteer, CAL, Standard Frame, Regular Lift, Pallet Forks 1PF, Universal Skid Steer Quick Attach
This HD SSQA Pallet Fork will not distort unless 9,000 pounds of force is applied. I like a little reserve.
   / 2501 or 3301--Questions, Questions, Questions #7
There are two main reasons to ballast rear tires.
1. increase rear tire traction
2. lower tractor center-of-gravity for work on hills
The L2501, like my L3560, has modest engine power relative to weight. Not enough power to break rear wheel traction under most conditions. If light ground contact implements are purchased, rather than heavy ground contact implements, rear tire ballast may be necessary even for an L2501 but I know YOU will not waste money on light, marginally effective ground contact implements.
If you ballast L2501 rear tires for work on hills you may find you lack power to climb with a heavy implement mounted on the Three Point Hitch. (depending, depending)
If you intend to work on hills and prudently decide to load rear tires, spend the additional money for L3301.
If I were to order a Kubota L6060, 4,023 pounds bare tractor, 62-horsepower gross, a high power-to-weight ratio, I would include loaded rear tires (probably radial tractor tires) and possibly cast iron wheels weights to make sure I had enough traction to get that 62-horsepower to the ground.
I have owned three tractors. None have loaded tires.
People often buy SUBCOMPACT tractors, like Kubota BX, primarily for lawn mowing, plus a little landscaping work with the FEL in the suburbs. Garage space is often tight. In this scenario where no additional Three Point Hitch implements are likely a ultra compact ballast box, slotted for garden tools, makes sense.
For an L2501/3301 or L3560 order an implement for Three Point Hitch counterbalance. Box Blade is most frequent choice. I often moont a Cultipacker, which is very compact in size, yet heavy.
LEVERAGE makes a 600 pound counterbalance implement protruding 48" to the rear of tractor more effective counterbalance than 600 pound implement protruding 30".
   / 2501 or 3301--Questions, Questions, Questions #8
   / 2501 or 3301--Questions, Questions, Questions #9
I agree with Jeff with everything except post #7. The 2501 needs tire ballast and 3pt ballast. You won't run out of power even on ridiculous hills and even with loaded tires and a heavy implement. They easily spin loaded tires in low or medium. Plenty of traction power.
But... If you run heavy implements that draw lots of PTO horsepower, the upgrade to a 3301 or 3901 is worthwhile. I've run out of power mowing heavy fields (grass over 6ft tall) stupidly using my 6ft finish mower. That's a big mower, and not all all applicable to the terrain. But it was a small patch and I got through. Its the only time I wanted more power.
To go back to the weight issue, Jeff is on point. The standard L series is light. Strong, and even with ballast, too light. If you mow your lawn (like I do) that's an advantage. But I doubt you'll be impressed. I suggest you get some seat time on them, the Grand L's and the MX.
   / 2501 or 3301--Questions, Questions, Questions #10
The only difference between a L2501 & L3301 (L3901 or my old L3200 too)is emissions & HP. Both will do the same work & pull the same load. More HP will just go faster.
No matter if you have loaded tires or not, you need lots of ballast on the 3pt. My L3200 would get very sketchy at max lift with lots of ballast & loaded R4s.
The SSQA is very worthwhile. I use pallet forks more than a bucket.
A L3560 is double the weight of an economy machine. It will lift & pull more. But at about the HP of a L3301, it has a worse power to weight ratio. My L4060 is tapped out on power on hills roading or mowing.
The grands are a lit more tractor. More weight, better transmissions (2 speed HST+ ontop of the same clunky 3 speed unsynchronized gearbox or GST). Options for a cab & more hydraulics.
My only regret in upgrading from my L3200 to my L4060 was not being able to afford more HP as I do a lot of roading & mowing.
2018 F550 Bucket Truck (A56438)
2018 F550 Bucket...
2022 KOMATSU WA500-8 WHEEL LOADER (A60429)
2022 KOMATSU...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
2016 Freightliner Bucket Truck with Altec LR756 (A56438)
2016 Freightliner...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
