What Toilet Brand Would Buy??
   / What Toilet Brand Would Buy?? #21
Kohler Highline Classic "Comfort Height".
I replaced the builder's toilets in my last house with these and specified them in the new house I had built. They do not clog.
   / What Toilet Brand Would Buy?? #22
Consumer Reports rates the Kohler Highline Classic as the second highest toilet. They also list it as a pressure flush vs gravity and there are reports of a few problems with the Flushmate pressure tanks. I am not experienced with pressure tanks on toilets and the house I need to replace a toilet in is on a well with the pressure low. How much pressure do you have?
   / What Toilet Brand Would Buy?? #23
I installed a Jacuzzi (16.5" not including the seat) a few years ago. It is a 2 speed unit and has worked well. Cost was about $170 at Lowe's. The mechanism inside the tank developed a leak. The handle broke, too. Those were fixed under the warranty. I suspect the internal mechanism will have to be replaced periodically.
   / What Toilet Brand Would Buy?? #24
I had picked up a "glacier bay" store brand dual flush from Home Depot in a quick fix situation about 2 years ago. It has worked better and has a better finish than our other Kohler toilet. I like it enough that 2 more of them will be going in the new home we are building.
Yep, I have 2 also. Work fantastic
   / What Toilet Brand Would Buy?? #25
CR is wrong - the Kohler Highline Classic is "Single-flush gravity uses the force of gravity and a precision-engineered tank, bowl and trapway to create a strong siphon during flushing"
We were on well at the old house - no problems. We're on community water in the new house but the pressure is often low. It just takes longer for the tank to fill.
   / What Toilet Brand Would Buy?? #26
Not familiar with the "Flushmate" assisted toilets? Let me explain it this way...picture being on the tarmac when a 747 takes off! I have 3 Kohler's here and have to warn guests to be prepared for the flush (not as bad as some European toilets that will send a splash of warm water up, followed by warm air, all in a plan to eliminate toilet paper). But they work great. As I understand it, the thing to look for is the diameter of the internal "guts". The more expensive toilets will be larger. And yup...the Flushmates have had some issues that resulted in a recall (it's a plastic tank that resides inside the water closet) and I understand they will need replacing sooner or later (warranty is 10 years I think).
   / What Toilet Brand Would Buy?? #27
CR is wrong - the Kohler Highline Classic is "Single-flush gravity uses the force of gravity and a precision-engineered tank, bowl and trapway to create a strong siphon during flushing".
The Kohler Website also says the Highline Classic has a pressure system, CR appears to be correct.
   / What Toilet Brand Would Buy?? #28
I'm not a plumber, but I have 14 bathrooms across my various real estate holdings. I like Toto the best and as the need arises I'm standardizing on them. I like the insulated tank models because I have high humidity.
Least favorite toilet brand is Mansfield, I only have one of them.
   / What Toilet Brand Would Buy?? #29
Consumer Reports lists
St. Thomas by Icera Richmond ECO (6123.218, 6125.028) toilet
As their top choice. I am not familiar with the brand but like the style for one of my houses but do not want to get into proprietary flappers, etc. Anyone have one of these?
   / What Toilet Brand Would Buy?? #30
I'm loath to buy new toilets as the older ones even up in the 1980's are so simple and effective if not max water savers... but if you flush twice how are you saving?
As a property manager I have had lots of low flush horror stories... some, even the manufacturers gave up on.
When I buy new... I buy only Toto... I believe the most common model I buy is Drake and they don't cost a lot over the box stores from the wholesale house.
Toto is the only toilet my plumber will put in commercially with a tank... Restaurants mostly.
Whatever you buy... pick up an extra ballcock and flapper... brand specific... as there are so many variations it is no longer guaranteed to be on the shelf everywhere.
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A60429)
2024 CATERPILLAR...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Peterbilt National NBT40 Crane Truck (A60460)
2015 Peterbilt...
2020 DRAGON ESP...
