tv antenna
   / tv antenna #151
And include a picture of your tractor and any valuables you have in the house, too... ;)
Nobody wants stuff I have out at the ranch.
2006 photo. It hasn't gotten any prettier. I wish the prior owner hadn't stored it outdoors since new in 1980. (But it's a Yanmar. It continues to run like new).
After the digital conversion I started with TV Fool and the related FCC (?) reception database and learned of the weird small stations at random points on the compass. But all the biggies in SF showed 'probably not'. I thought that the premium antenna might overcome difficult reception, but it just can't see over the hills/mountains between here and SF. Map. (zoom out). I'm in the hills SW of Santa Rosa. 60 miles NW of Sutro Tower in SF and behind several hills/mountains. Mt Tamalpias is 2500 ft and directly in line. Apparently all my pre-digital reception was reflected off the atmosphere.
   / tv antenna #154
Here's KNTV. Unless you're on a hilltop,you're screwed.I looked at your local stuff and you're right,it's crap.
RabbitEars.Info
   / tv antenna #156
RabbitEars.Info
Thank you! That pretty map conveys a lot more information than the numeric data I found after the digital conversion.
You're right, the map shows I'm simply hoping for the impossible. Most everything for miles around is white (no signal) with a few hill peaks pale red, 'maybe'. The ridge blocking my line of sight is all white, no signal there. Bah.
Thanks guys for the encouragement, and the realistic information.
   / tv antenna #157
Received Monterrey and Sacramento and all the Bay Area Stations before Digital...
Now, there are more channels but still only half in English...
No more Monterey and Sacramento...
The old rabbit ears have zero margin for error to pull in the regular 50 or so channels...
Even having people walking around can affect the signal.
It was nice getting all the local blacked out Raider, Athletics and Giants with a regular old antenna on the old Zenith Console...
Looking out the window I can see the Oakland Coliseum and the Old Candlestick Park... but pulling in Monterey was sweet... old channel 8
   / tv antenna #158
Two stacked Channel Master Digital Advantage CM2020 antenna with a top mounted amplifier and FM trap. Use real RG-6 low loss cable, a 30+ ft tower and a rotor . You will bring in those weak channels .
   / tv antenna #159
I think in his case it's not that they are weak.... they are non-existent due to the terrain.
   / tv antenna #160
Sometimes you have to just try it out. My address shows i get one channel good and the rest poor. I don't get the good one but do get a number of the poor ones. I also moved it around my property, to see where i got the best reception, some places none what so ever. My current antenna, points south and looks like a somewhat smaller version of one i had 20 years ago. It doesn't get lower frequency channels that aren't there anymore, but it's still pretty big and narrow beam. I would have used my old one, but apparently half of it didn't make the move.:confused3:
I'm thinking of make another antenna to point northish to see what i get. I'll be checking the frequency of the northern stations and make on more tuned to those, maybe.
Deere 700K LGP (A50123)
Deere 700K LGP...
2019 John Deere S780 Combine (A53342)
2019 John Deere...
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2014 Ford Escape (A51694)
2014 Ford Escape...
WHIRLPOOL REFRIGERATOR / FREEZER (A51248)
WHIRLPOOL...
