Steam pot
   / Steam pot #11
Maybe it's from when you fill it and all you need to do is to wipe it off with a wash cloth? If you have a pin hole leak, I'm betting that as you use it, the Calcium will eventually plug it up. I remember Grandma's old kettle; she put a marble in it to keep it from bumping and it gathered up a lot of the calcium and grew quite large. A good "bump" could possible poop a little water out the spout too.
I would wager that the marble that Grandma used was made of actual marble.
I tried that 'trick' with a cast-iron kettle on my wood heater... the glass marble that I used eventually shattered. Antique shops may be a source for an actual 'marble' made of marble.
   / Steam pot
Yeah I was hoping calcium or corrosion would take care of it for me.
I have been either not dripping or wiping it up. It generally doesn't bump. To get a good boil it has to be 110* in the den!
I'm 100% sure I have 2 pinhole leaks.
I dumped some of the wifes ground ginger in there hoping for a seal.
Been wondering about a chunk of beeswax put in a really hot dry kettle.
   / Steam pot
Top of stove, front of kettle, bottom of kettle. 20181117_205400.jpeg20181117_205420.jpeg20181117_205434.jpeg
   / Steam pot
If you need it I can send you a marble tile scrap. It's not round though.
   / Steam pot #16
Y'know, that's not a bad idea! No one said that the 'marble' had to be round... i just assumed so due to 'marbles' vs. 'alleys'.
Blinkers "off".
Grandma's marble more than likely was a ceramic...or "clay" marble. There were a lot of those around in those days.
   / Steam pot
The ground ginger plugged the 2 leaks in question. Then some more happened. So much for a quality casting....
So I finally bought a trivet, as recommended by oosik.
Its a cool one. CSA commemorative brass.
2004 JOHN DEERE 650H LGP CRAWLER DOZER (A60429)
2004 JOHN DEERE...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2024 CATERPILLAR 255 SKID STEER (A60429)
2024 CATERPILLAR...
John Deere Z994R (A60462)
John Deere Z994R...
iDrive TDS-2010H...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
