County Line Post Hole Digger - Watch which one you get!
   / County Line Post Hole Digger - Watch which one you get! #21
I bought a County Line PHD a few years ago, used it, then sold it. It worked fine. I think you may have just got a bad one.
   / County Line Post Hole Digger - Watch which one you get! #22
That's too bad. That is one ugly weld. I would take the unit back and exchange it.
Just bought the same one myself and all the welds looked great and I was impressed. Good value IMO.
I'd clean it off and weld it, as it would take less time and guarantee that the weld was good.
Should have called everything attchments. Travis would have set you up
Not in the time I needed though. Had to get a fence built before this weekend which the only reason I went this way. I actually called EA about getting a post driver Monday but just couldn’t wait for it to get here.
The Missus surprised me with the fact that we are picking up a horse this weekend. Wasn’t expecting that. lol
That is the plan... As soon as I get my shop put up and wired. It will be springtime. The past seven weeks have been crazy busy trying to get the new place up to snuff.
   / County Line Post Hole Digger - Watch which one you get! #25
I have a few things from TSC. Most have been ok for the price. I tend to only purchase the heavier items. I know some of their stuff was King Kutter, which is made about 45 miles north of me. 30 years ago I did some work for them. But I don't think TSC buys from them any longer. Not sure as to why.
Two years ago, my son bent my PHD with his 25hp tractor. I had used it for 30 years on my 35hp tractor with no problems. Going to fast and hit a rock. Also bent to top link on the tractor.
Hard to tell where some of this equipment comes from today. I believe in checking it over as best I can.
   / County Line Post Hole Digger - Watch which one you get! #26
I'm sure you have valid reasons but I don't agree. I dug 45 holes today with the County Line 3pt PHD. It worked flawlessly. I have seen a number of others and don't see anything to warrant the product costing twice as much.
The TSC 3pt PHD may be wonderful,..... but MANY of their other implements are not!
   / County Line Post Hole Digger - Watch which one you get! #27
I suspect TSC found a cheaper supplier than King Kutter.
That cheaper supplier appears to be Tarter Gate.
   / County Line Post Hole Digger - Watch which one you get! #28
Evidently, it wasn't that TSC's PHD was cheaply built.
Speed, RPMs, that's what I really don't like about the Tier 4 tractors. You are compelled to run them at a much higher RPM in order to keep the emission system from clogging. Not good when running such implements as a post hole digger or even in some cases operating a backhoe. :(
   / County Line Post Hole Digger - Watch which one you get! #29
On tractors with DPF that do regens (which is all except Branson), they'll just regen more often if you idle them around all the time.
   / County Line Post Hole Digger - Watch which one you get! #30
I bought one of these diggers last year and dug many holes with it. I dig at an idle and it seems to work pretty good. Dug hundreds by hand over the years so this is a treat to have IMG_3779.JPGIMG_3780.JPG
   / County Line Post Hole Digger - Watch which one you get! #31
Should'nt it of broke the shear pin ? Maybe you all have wrong size shear pin on it . If I recall correctly from years ago they use a number 5 ?
Mine specifically calls for a 5/16x3”, Grade 5 bolt.
   / County Line Post Hole Digger - Watch which one you get! #33
Agree, it should have sheared the pin. It also calls for a Grade 5 bolt. But it didn't. Sometimes it happens. But I think speed was the problem. He had never used it before on his tractor and trying to go fast in ground with large rocks. Too small a tractor (frame, no hp). I will need to check the bolt, to make sure that it has not been replaced with the wrong one. In a rush, I could have done it myself.
   / County Line Post Hole Digger - Watch which one you get! #34
Mahindra too, right?
   / County Line Post Hole Digger - Watch which one you get! #35
Those have DOC not DPF. My understanding is that DOC doesn't need a regen. Branson has a DPF that does low temp continual regen, and mechanical fuel injection. It works well if you run the tractor hard enough often enough. A few guys who only do loader work at low rpms have had the DPF warning light come on. Then since there's no discrete regen you have to do it yourself by running it up and down the road for a while, or something similar.
   / County Line Post Hole Digger - Watch which one you get! #36
I realized my mistake right after hitting "post reply" but once on the internet always on the internet.
   / County Line Post Hole Digger - Watch which one you get! #37
The TSC post hole auger is pretty bullet proof in my book. It will run for years without a drop of oil in it. I know because my buddy has one and he's dug a couple fences and a pole barn with it and I've borrowed it a few times over the past 3 years he's owned it. I borrowed it last week and decided to check the oil before I ran it. See attachments.
   / County Line Post Hole Digger - Watch which one you get! #38
View attachment 583769View attachment 583768
Very funny. Loved the screenshots.
   / County Line Post Hole Digger - Watch which one you get! #39
Now I won稚 try and tell anyone thier stuff is top notch quality but the fact is at the price point it sure is worth buying.
It seems that everyone one I know who has purchased something has had no or very minor problems. Myself having had no issues with 3 attachments purchased and we are talking having those attachments for 15 years.
VOLVO A40D OFF ROAD DUMP TRUCK (A60429)
VOLVO A40D OFF...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
2003 CASE 590 SUPER M BACKHOE (A60429)
2003 CASE 590...
2022 Chevrolet 1500 Silverado Crew Cab 4X4 Pick-Up Truck (A59230)
2022 Chevrolet...
