Massey 1760M or 4707 or ? = Stuck newbie
/ Massey 1760M or 4707 or ? = Stuck newbie #1
Crazydad
Texas
Massey Ferguson 4707 and MF 65, Kubota KX-040
Hi all,
I have been lurking here for a few years and enjoying all the info everyone brings. I live in central Texas and have about 8 acres divided into lots that I have to get ready to develop. That includes building a gravel road, removing cedars and everything but oaks, scrapping up the rocks to bushhog yearly and build fencing.
I also have taken over a 125 acre family property in central Arkansas with trees, about 50-60 acres cleared with weedy hay growing, a 1.5 acre pond to maintain and about 1500 gravel road. There is a 1960ish Massey 65 there with a 6 Shredder there that I have been learning how to use (run one of these out of gas and you will quickly learn all the parts of the motor).
The plan is to buy a good tractor to work in Texas for a year or so and trailer it to farm about 4 times a year to work while I am there. Then later permanently move to to the farm. The tow vehicle is a newer F250 diesel.
Ive looking at Massey because my current tractor sits outside and always runs. I was looking at the 2606h but from this site I think a cab is what I need. So I am at the 1760M but after speaking with Brunos tractor in Cabot Arkansas he said I need a bigger tractor with more hydraulics for attachments so in comes the 4707. Both have good reviews and their about 6 thousand or so apart in price so bigger is better but then the trees come into play and the 7 foot width and trailering.
For attachments I need a box blade the width of the tractor, front controls for a grapple, shredder, and some kind of rock bucket to start. The above dealer sells you attachments a little over cost when you buy the tractor like a pick you package. But they are Woods and I dont know if the quality is ok? Now the big one you guys have me hooked on is the front shredder or a mulcher! Man would that help me at both places, at the farm I tried the mow in reverse with the shredder up and it tore though all the under brush and small growth up to 3? Maybe that one is a if it sounds too good to be true then it is not.
After reading here I looked a koti and LS but the price is the about the same. I just left the farm and forgot to get pictures but I will see if I have old ones.
So do I get the 4707 for a great price from brunos and spend the bucks for a 28 foot trailer and deal with the extra height. Or go with the 1760m and possibly have to sell it to run bigger attachments later and have more depreciation on the sale. Thanks for your help.
058CA528-B393-4727-B844-300082ED1F88.jpeg[SUP][/SUP]
/ Massey 1760M or 4707 or ? = Stuck newbie #2
Towing - I have an F250 as well so guessing you are around 15k for max towing capacity not considering combined weight limits and such. 4707 ROPS is 7125 base weight, 8k with loader no bucket. Once you load the rears (if you do) + 1200# and the cab and fluids you are probably at 10-11k no other implements. If you have a 3000# trailer you are almost at your limit. The math is probably off, but you get my meaning. Consider this carefully...weight adds up very fast.
Land clearing - tractors arent the best at this. Cedar trees have terrible root systems, you probably cant just push them over easily but will see if others here have more experience. Do you need to excavate for the road? Just wondering if you are going to need to rent or hire some of this out. Typically roads are built with bulldozers and excavators :)
The 4707 will be great for mowing (provided you dont have tight spots), fencing - auger I assume.
A few questions:
1. Are you planning on baling hay in the future? If so you will eventually need more tractor for 60 acres.
2. Are you talking about a forestry mulcher on the front? If so you are you sure you have the hydraulic flow to run it?
Forestry mulcher - you need different glass if you get a cab...wood can come flying out and crack standard glass. If you dont have a cab and adequate flying debris protection, you should not be using one. I had a contractor do 20 acres of beetle kill pine on my place, 100HP fecon. It threw large chunks of wood 50+ yards at Nolan Ryan speeds.
/ Massey 1760M or 4707 or ? = Stuck newbie #3
The 4707 is just so much more tractor.. also if you have any little ones that would ride with you the buddy seat on 4707 is nice. The tractor is a good bit larger though, for better or worse. Kubota m7060 is similar size (cab smaller) but weighs a bit less also which may be easier on your truck/trailer if that’s an issue. I had it priced around the same as the 4707. Kubota reliability is good also- this 4707 is newer but so far haven’t seen/read many issues.
Jchonline, you are right I will be at the towing limit but after reading a bunch on the ford truck enthusiast forum the consensus is most are running fifth wheels over weight and the truck handles it fine. But I don’t like the idea of getting in trouble. It’s a 11 hour drive. I have been speaking to Texas Pride about a trailer and they recommend 8000 lb axels to be safe or perhaps 9000 but the price goes up quick.
As for land clearing, trees in Texas are not too tall so in the past with rented equipment like bobcat I have push them over and pushed on the root ball until the come out then push to a burn pile. On larger I just cut them and come back in a year for the roots. Sounds like the forestry mulcher is out with a cab. How about the brush shark, land shark, lane shark type attachments with a cab.
For auger around here the big thing is the belltec tm48 for the rock and straight holes. Some guys just to holes for posts as a business. It’s around $9000 not too many used around.
Not going to bale now but maybe later. Someone was baling for free just to keep it mowed. I’ll just mow it and ask my tax guy if there would be any benefits to selling hay for a small profit this year. Next year I might bale or turn the soil and replant to get the junk out. When you say more tractor for 60 acres do you mean bigger the the 4707. Then I would get the smaller one for now. If you look at the picture that’s the smaller 5 acres fenced around the house and pond. Then the bigger area beyond. I need to clean everything up and push back the tree creeping back into the open field.
CHF4, thanks I’ll check out the m7060. If it’s the same price that’s good. Thanks.
Here is some pictures of the pond at the farm I have to clear everything except the two tall pines. All those trees suck out the water and can compromise the dam. The trail is the dam and both sides must go. I will cut down the bigger ones and pull the out with the tractor. I was hoping I could shred most of this.
This is the Texas property. Most of this needs to go. I keep some cedars that have straight trunks and are not near oaks to have some green after I limb them up.
D39E5035-6EDD-4842-A683-A5EF99DCD9E0.jpeg1479B76F-7215-4145-A8B4-6EFCACF46B19.jpeg6F73F627-A3E5-49C8-B8EB-938311384111.jpeg
/ Massey 1760M or 4707 or ? = Stuck newbie #8
1. Trailering - that trailer is probably going to weigh 4000 lbs itself, be sure to check. Like I said it adds up quick!
2. A Tractor is not a SS. If you go pushing on trees like you can with a SS, you are likely going to bend the FEL arms. As you know, SS arms are reinforced by the frame when in the fully down position, giving incredible strength. Tractors with a FEL do not have this support.
3. I grew up in TX, still have 100 acre family hay/cattle farm in Athens. I know cedars all too well, I just havent pushed them over with tractors :)
4. Forestry mulcher - you may be able to get bulletproof or comparable glass installed, it will just cost more. I am not sure. I know for SS mulchers, they require special glass for the mulcher models. Not sure on the land shark, but a well made bush hog on a 4707 should cut some serious growth. Some rotary cutters can work on 4" saplings...that is some serious cutting!
5. Ouch on the auger, any chance you can rent one? Assuming you dont want to go into the fencing business :)
6. Baling - good, it is expensive. Get ready for a new tractor and some serious equipment investments if so. Another option popular in TX is baling on the halves. You let a larger operation bale it, they take 1/2 and leave you 1/2 of the bales. You could either sell them or use to feed as needed.
7. More tractor IF you are planning on baling/haying is what I meant. The 4707 seems great for 60 acres for everything but baling.
8. Keep in mind if you are mowing, you are not going to want to mow 50 acres with a bush hog. It will take you days. You may want something with more width (multi spindle, batwing, etc). We used what I called "weed slingers" that was a gearbox tied to the blade and wheels. It was a pull behind. Wheels turned, blades turned. We use this for field mowing when not haying. Not sure what others use today.
/ Massey 1760M or 4707 or ? = Stuck newbie #9
A user on these forums "Bigpuddie" has a 4707, he loves it, you may want to PM him for more feedback.
/ Massey 1760M or 4707 or ? = Stuck newbie #10
You may very well be able to pull some of these right out of the ground. Tractors are great at pulling. You will need a drawbar and an awesome chain. Just dont pull in a situation where a tree could fall on you (ie get a chain longer than the tree is tall). The shorter cedars seem fine. Other options are tree pullers (some have hydraulic jaws) that you can grab the base and rip it up. For the cedars that might work well. For tall trees it is a bad idea as one could come loose and fall toward you.
/ Massey 1760M or 4707 or ? = Stuck newbie #11
Thank you, I his posts are one thing that helped me make the decision. And the fact that the 4yr old Deere 5075e that was brought out died on me after being in the shop for a month. It threw some codes, wouldn’t shift on the fly without cutting off and just was a little rougher than the MF that I demo’d. I had thought I wanted the JD..but not after that experience. Also 4707 has more options like the M yet a bit cheaper than the M.
/ Massey 1760M or 4707 or ? = Stuck newbie #12
Get the 4707 and dont look back. Fantastic machine. Very comfortable and capable. Get a nice heavy grapple, a good quality rotary mower, and a heavy rear blade or box blade. Woods makes good stuff and there is a $400 rebate if bought at time if tractor purchace. Rhino makes excellent rotary mowers. You will need a 14k or 16k trailer.20190113_164723.jpeg20181203_140453.jpeg20181026_114133.jpeg20181026_120043.jpeg20181025_085143.jpeg
Thanks on all points. I was going to get a bolt on blade and push stuff over with the bucket but I don稚 want to bend the forks on a new $45000 tractor.
The area in Arkansas has lots of farms and cows not so many horse ranches so looks like baling would be a break even with the extra costs. Now here in Texas I could make good money from selling alfalfa, just to far to transport from Arkansas.
It does take a few fulls days on the old tractor to mow but that old tractor is scary. A batwing 12 foot would be good.
Get the 4707 and dont look back. Fantastic machine. Very comfortable and capable. Get a nice heavy grapple, a good quality rotary mower, and a heavy rear blade or box blade. Woods makes good stuff and there is a $400 rebate if bought at time if tractor purchace. Rhino makes excellent rotary mowers. You will need a 14k or 16k trailer.View attachment 589676View attachment 589677View attachment 589678View attachment 589679View attachment 589680
So far no one recommends the smaller 1760m. So I guess I need to deal with the PITA to move it back and forth. I will just have to be careful in the trees. How are your lights at night? Do you think you need LEDS. Are the wheel weights something you can take on and off easy, it does not look feasible. What was the production date for the steering issue, the one I was looking had a date of 3-18.
/ Massey 1760M or 4707 or ? = Stuck newbie #15
Not positive on the exact production date window, but you may be ok. The lights are very good. Weights not an easy on and off. As for the 1760, it's a great machine, but you said you would be ripping up cedars and rocks, and cutting in driveways. I just dont think the 1760 would be heavy enough. If you were just maintaining roads, its would be just fine. If you are really concerned about weight, a Kubota m7060, Case 75c, and New Holland Powerstar 75 would be lighter and more agile and all good machines to consider. The Kubota has the least desirable emissions with its DPF and the orange paint fades quickly if left outside. The 4707 will really shine doing field work and whenever its heft is really needed. It also has the most comfortable cab by far, followed by Case/NH.
/ Massey 1760M or 4707 or ? = Stuck newbie #16
You need a utility tractor if you live on a farm, moving hay alone takes a tractor of this size to do it comfortably. You have a bunch of field mowing ahead of you as well. If you want to forget about haying or a mowing 60 acres in a reasonable amount of time, then you can consider a smaller machine. However to me once you finish with the TX clearing the geared shuttle will be the best choice.
Thanks guys, I will think about getting a skid steer on tracks used at some point with a front bush hog to get into tight places in the trees. That will offset the bigger tractor. With the extra cost of the trailer I will have to wait on the batwing. I am thinking about tinting the windows for UV protection.
/ Massey 1760M or 4707 or ? = Stuck newbie #18
I know this is slightly off topic, but just curious your opinions, Insurance yes or no on new tractor? If yes, besides agco, who else? My insurance co doesn’t provide.
I realize it people have different opinions, just would like them. I grew up driving tractors & am pretty conservative/careful while operating. Will use for typical things- mainly bushhogging & mowing/some log moving/brush clean up/dirt moving. (Getting 4707 w/ cab).
/ Massey 1760M or 4707 or ? = Stuck newbie #19
I decided to make a new post but any thoughts here would still be appreciated. Thanks
/ Massey 1760M or 4707 or ? = Stuck newbie #20
I changed my homeowner's insurance to a farm policy with inland marine coverage. It covers the tractor and implements both on and off premises for both comprehensive and liability. My insurance went up $460/yr. Including glass coverage.
32in. Tilting Bucket Mini Excavator Attachment (A59228)
32in. Tilting...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60432)
KNOW BEFORE YOU...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
UNUSED IRANCH MINI EXCAVATOR QUICK COUPLER (A60432)
UNUSED IRANCH MINI...
UNUSED IRANCH 38" MINI LAND LEVELER (A60432)
UNUSED IRANCH 38"...
