any toro groundsmaster fans on here?
   / any toro groundsmaster fans on here? #641
DO you have a drawing of the 4x4 version of the drive train?
Without being able to see a 4x4 in person, it's hard to determine where the trans and driveshaft for the rear steering axle bolt to the axle from diagrams.
   / any toro groundsmaster fans on here? #642
Thanks for the reply! Mine looks identical to yours in that pic but with only 2wd setup. I will be building a new frame. Kubota style with all of the appropriate gussets and such to mount everything including my Toro Wheelhorse 520h sheet metal (Obviously with some modifications where needed).
So your planning to make the front axle the steer axle?
I have a Kubota BX 2200 front 4x4 axle and wheels that are in great condition that will be part of the build that is driveshaft driven.
What is the tire size? How are you going to get the driveshaft speed and rotation right?
So I wasn't sure if there was a 4x4 conversion kit for the current model I have (93 325D Groundsmaster) that I could adapt into the build. Are there actual kits based off of certain models for this type of conversion or am IK looking at a parts swap or trans rebuild of sorts?
Thanks.
No conversion kits available that I know of. Lots of parts for sale on ebay.
So I would need a 4x4 Front Axle from a 325D or similar 4x4?
Yes to get a driveshaft output
No
There is only a driveshaft. It attaches to the front axle and runs back under the hydraulic motor/transmission.
   / any toro groundsmaster fans on here? #643
Found a picture on eBay of your 2WD axle that shows the input gear #14 where the trans bolts to the axle. The 4WD axle would have the pinion gear shaft, #8 (that goes through the input gear #14) and the driveshaft attachment flange #22 sticking out where the red arrow is:
   / any toro groundsmaster fans on here? #644
So I should just be able to get parts #22 and #8 theoretically? And then that would allow for the addition of the drive shaft to the other axle?
   / any toro groundsmaster fans on here? #645
Yep, theoretically, plus a few more. You could compare the 2WD parts list to see what else is different.
   / any toro groundsmaster fans on here? #646
Okay. Will do. Where would be a good place to get the parts that I need? Any suggestions? I'm okay good used parts as well.
Andrew
   / any toro groundsmaster fans on here? #647
Looks like other than the Pinion Shaft (#8) I will need #20-#23 which will be the Oil Seal, Flange, Washer and Nut... Then obviously a drive shaft and whatever mounts/ bearing is that has them. But these parts above will yield 4x4 PTO...
Just to clarify... That Flange is what couples the internal pinion and the exterior 4x4 drive shaft with use of that large washer and nut as well as the bolts that are driven into the flange from the drive shaft? Sound about right?
Also, I'm checking and it seems most of the 4x4 if not all don't have a part number for the pinion shaft from the 4x4 assembly?
Andrew
   / any toro groundsmaster fans on here? #648
Andrew
Look for TORO Commercial dealers in your area. There are a lot of online sellers also.
eBay in my first check for used parts.
Right, But I'm concerned that the seal might not fit where the cap is on your housing, since the 4x4 housing is a different part number.
Also you didn't mention #24, the shims, so I don't think you have ever setup a ring and pinion or have the tools to do it. Although probably not as critical on this low speed differential.
Andrew
That is because it is matched to the ring gear and is sold as a pair.
   / any toro groundsmaster fans on here? #649
Okay I will do that. I did check E-bay and found the flange and oil seal.
I should be able to find the oil seal with measurements...
No, I have never set up a ring and pinion gear. So if I also include the shim from a 4x4 axle that would be ideal. correct? Or will that need to be a test and fit type of situation?
I thought I read something like that in regards to matching them. I guess that's why there's no part number for ring gears either. ;)
It would be nice if I could find someone in the area that would be willing to trade my 2x4 axle with a little chash for their 4x4 axle. That would make this a lot easier. But I like learning.
   / any toro groundsmaster fans on here? #650
No , it isn't "the shim". Look at the parts list again. There are several thicknesses.
Yes.
It would help to know where your area is.
Since you like learning, search YouTube for "set up ring and pinion".
This is not a project (changing the 2WD axle to 4WD) that I would try.
1694 (A58375)
1694 (A58375)
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
1998 MACK RD688S 80 BBL BOBTAIL VACCUM. (A58214)
1998 MACK RD688S...
2000 FORD F-350XL SUPER DUTY FLATBED TRUCK (A58375)
2000 FORD F-350XL...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
