Welding I-beams together
   / Welding I-beams together #1
bdog
Elite Member
Texas
John Deere 6130M
I am building the rafters for my carport. 12” 14# W beam with a 4/12 pitch. Span is 29’
I have built multiple steel buildings but all had a single pitch roof and I have never had to weld beams together like this.
Does this look adequate? I am not sure if I need to fish plate it or need more reinforcements.
Disregard the grey oval plate on the bottom. The beams are just resting on it.
   / Welding I-beams together #2
I am having a hard time telling if the plate is on the side or on the bottom to make a triangle.
Now the picture makes sense to me. I wasn't even seeing it in the right perspective. It looks good to me, but I probably, doing everything overkill, made the triangular plate a little bigger. Even slightly bigger would make a HUGE difference and weld strength not as important.
   / Welding I-beams together #3
Probably fine in Texas (no snow) as long as the roof is only seeing “normal” dead loading (use regular roofing material) and minimal live loads - no helicopters or elephants up there.
This assumes you are making at least 4 of these......how many are their? Or what’s the slab in the other direction?
It is a 29’ span for the I-beams and then 26’ in the other direction. There are only two of the I-beam structures. The purlins going crossways will be 10” C purlins and then it will be sheeted with 26ga R panels.
The material sizing and spans were chosen from the steel building suppliers chart and were chosen toward the larger side of materials. I am not really concerned about the material size rather just the weld.
The triangluar piece is cut out from a 4” I beam I had laying around. I didn’t have any extra of the 12” or anything larger on hand to make the piece with.
   / Welding I-beams together #7
So the purlins span 26’? That’s more load than I was expecting.......
Yes - they span 26’.
8” purlins are good to 25’ and 10” are good to 30’. I am barely over 25’ but went with 10”.
My last building was a single slope but was 15’ spanned by the beams and 25’ spanned by the purlins and I used 8” 10# W beam.
   / Welding I-beams together #9
If the weld shows a root bead on the back side as in pipe line welding you'll be good. If not grind/clean the back side groove with the angle grinder and run a bead in the back. Don't be surprised if the mid section of the beams draw in to give a slight inward bow. Hopefully not.
   / Welding I-beams together #10
All your stresses are in the flanges not the web. Your picture only shows the web.
The question is if you have to ask people on an anonymous tractor forum if your structural welds are good enough for a building then you probably have bigger worries like ‘is this building going to fall on my head - or my grandchildrens heads - or the neighbors...’
2016 Chevrolet Malibu Sedan (A59231)
2016 Chevrolet...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
2022 BOBCAT T770 SKID STEER (A60429)
2022 BOBCAT T770...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
207275 (A52708)
207275 (A52708)
