3-Point Hitch 1705 stabilizer
   / 1705 stabilizer #1
hoguester
central, ia
MF GC1705
Hi all. First time poster, long time reader. Gotten a wealth of information from this site over the years, but have a problem I haven't had any luck searching an answer for. Appears I overworked my 1705 and broke the stabilizer on one of my control arms. I'm having a hard time finding a replacement. Hoping for some advice on an online resource. I tried the online agco parts book but they only listed each individual part rather than the entire stabilizer. I have a couple of pictures but I think I need more posts before I can attach them. Thank you
   / 1705 stabilizer
I you replace the two threaded pins with an appropriate size clevis (same as the other end that's already on there) these should work..
Thank you. I'll double check those measurements.
   / 1705 stabilizer
Trying to attach pictures...
   / 1705 stabilizer #5
So what actually broke? The threaded part of the square piece?
   / 1705 stabilizer
The threaded part on the turnbuckle nearest tractor broke and the other pin that attaches clevis to farthest end of 3 point arm. Hope I'm explaining that well. All I have left is pin, clevis, and broken threaded part that screws into turnbuckle and the clevis from the other end I found in the field.
   / 1705 stabilizer #7
Looks to me that they aren't sold as a unit (which is odd). You may want to go to your dealer and see if they have a way to order the entire assembly as 1 unit. This is one reason why the backhoe subframe is nice to have; the lower link arms cannot over travel and thus snap the (chintzy pot metal) stabilizers. Please let us know what you end up doing. If you find a viable alternative, I would replace mine.
   / 1705 stabilizer
I agree. They seem to be a rather cheap galvanized perhaps. I'm looking hard at the stabilworks.rocks for something stronger. Unfortunately he is a one man operation and seems to be very popular and is backed up with orders several months. I was hoping to avoid the dealer markup. Past experience was a rather high price tag. I'm going to call a couple of dealers today.
   / 1705 stabilizer #9
Have you tried TSC?
   / 1705 stabilizer #12
Have a similar issue bent the living heck outta one of mine. No clue how, but regardless did you wind up buying at TSC?
Or do you have a source?
   / 1705 stabilizer
As a temporary solution I pieced together a turnbuckle, clevis, and pins from tsc. For a permanent solution I placed an order for a set from stabilworks. I highly recommend stabilworks!
   / 1705 stabilizer
I would post a picture but the ads are blocking that button for me I think
   / 1705 stabilizer
Downloaded app so I can attach pictures. First picture shows stabilworks installed and you can see a little bit of temporary turnbuckle on the ground. Second picture shows stabilworks by themselves. Third picture shows temporary turnbuckle clevis and pins installed. Hope that helps.20191025_144529.jpeg20191018_162807.jpeg20190510_162806.jpeg
   / 1705 stabilizer #16
   / 1705 stabilizer
I don't have a backhoe so I've never tried to fold them up. I suspect they won't fold up quite as easy as the floppy turnbuckle clevis and pins but will defer to others with more experience.
   / 1705 stabilizer #18
Interesting, guess I need to go by TSC to get some that aren’t bent then order the stabilworks ones. Also I’ll take a look but I bet they will go ld fine.
   / 1705 stabilizer #19
Just put in my order. Stabilworks is currently backordered for 9 months. Yep told me I am in line expect an invoice spring of 2021..
   / 1705 stabilizer
Similar experience. I suspect he's a part time one man operation. Well worth the wait and also the reason for my cheap TSC temporary fix I pieced together.
2015 INTERNATIONAL PROSTAR (A59905)
2015 INTERNATIONAL...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
AUCTION STARTS HERE @ 9AM (A60429)
AUCTION STARTS...
2009 Ford F-150 Pickup Truck (A59230)
2009 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A60432)
UNUSED RAYTREE...
