3-Point Hitch 1705 stabilizer
   / 1705 stabilizer #1
hoguester
central, ia
MF GC1705
Hi all. First time poster, long time reader. Gotten a wealth of information from this site over the years, but have a problem I haven't had any luck searching an answer for. Appears I overworked my 1705 and broke the stabilizer on one of my control arms. I'm having a hard time finding a replacement. Hoping for some advice on an online resource. I tried the online agco parts book but they only listed each individual part rather than the entire stabilizer. I have a couple of pictures but I think I need more posts before I can attach them. Thank you
   / 1705 stabilizer
I you replace the two threaded pins with an appropriate size clevis (same as the other end that's already on there) these should work..
Thank you. I'll double check those measurements.
   / 1705 stabilizer
Trying to attach pictures...
   / 1705 stabilizer #5
So what actually broke? The threaded part of the square piece?
   / 1705 stabilizer
The threaded part on the turnbuckle nearest tractor broke and the other pin that attaches clevis to farthest end of 3 point arm. Hope I'm explaining that well. All I have left is pin, clevis, and broken threaded part that screws into turnbuckle and the clevis from the other end I found in the field.
   / 1705 stabilizer #7
Looks to me that they aren't sold as a unit (which is odd). You may want to go to your dealer and see if they have a way to order the entire assembly as 1 unit. This is one reason why the backhoe subframe is nice to have; the lower link arms cannot over travel and thus snap the (chintzy pot metal) stabilizers. Please let us know what you end up doing. If you find a viable alternative, I would replace mine.
   / 1705 stabilizer
I agree. They seem to be a rather cheap galvanized perhaps. I'm looking hard at the stabilworks.rocks for something stronger. Unfortunately he is a one man operation and seems to be very popular and is backed up with orders several months. I was hoping to avoid the dealer markup. Past experience was a rather high price tag. I'm going to call a couple of dealers today.
   / 1705 stabilizer #9
Have you tried TSC?
   / 1705 stabilizer #12
Have a similar issue bent the living heck outta one of mine. No clue how, but regardless did you wind up buying at TSC?
Or do you have a source?
   / 1705 stabilizer
As a temporary solution I pieced together a turnbuckle, clevis, and pins from tsc. For a permanent solution I placed an order for a set from stabilworks. I highly recommend stabilworks!
   / 1705 stabilizer
I would post a picture but the ads are blocking that button for me I think
   / 1705 stabilizer
Downloaded app so I can attach pictures. First picture shows stabilworks installed and you can see a little bit of temporary turnbuckle on the ground. Second picture shows stabilworks by themselves. Third picture shows temporary turnbuckle clevis and pins installed. Hope that helps.20191025_144529.jpeg20191018_162807.jpeg20190510_162806.jpeg
   / 1705 stabilizer #16
   / 1705 stabilizer
I don't have a backhoe so I've never tried to fold them up. I suspect they won't fold up quite as easy as the floppy turnbuckle clevis and pins but will defer to others with more experience.
   / 1705 stabilizer #18
Interesting, guess I need to go by TSC to get some that aren’t bent then order the stabilworks ones. Also I’ll take a look but I bet they will go ld fine.
   / 1705 stabilizer #19
Just put in my order. Stabilworks is currently backordered for 9 months. Yep told me I am in line expect an invoice spring of 2021..
   / 1705 stabilizer
Similar experience. I suspect he's a part time one man operation. Well worth the wait and also the reason for my cheap TSC temporary fix I pieced together.
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
1997 Sherman and Reilly Drum Line Puller Tensioner Trailer (A59228)
1997 Sherman and...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
HYD BREAKER HAMMER (A60429)
HYD BREAKER HAMMER...
2019 BOBCAT T450 SKID STEER (A60429)
2019 BOBCAT T450...
