DieselBound
Elite Member
Thanks for the encouragement. Used it another 2 hours this morning and am starting to get the hang of adjusting it by ear as I move along. With the extra weight, I don't need the scarifiers. It'll cut off a nice 2"-4" layer with ease. It turns up good sized rocks and carries them along for easy dumping. So far, so good.
Yup! the weight plus the cutting edge will really get a bite started and then just keep pulling down. I've moved along making rolls of sod as I went (curling up and on to the front of the box blade, thereby adding more weight for more bite). Slow and steady is the mindset to use. Going slow allows you to make fine adjustments to the fore/aft pitch for a more smooth grading. I find that finish grading works best in reverse: and this REALLY requires one to go slow! Here's some recent work I did (I am grading in a drainage "V" at the back of the house as the ground at the back slopes down to the house [I used a manual landscaping rake for smoothing and surface rock removal]):
