Mark @ Everlast
Advertiser
Not on my Everlast. Maybe the cheapest inverter model doesn't get one.
Which one do you have?
Once you become 1 with your welder (s) you won't be dependant on the door panel parameters or even meters. You just dial it in by sound. You'll know if it sounds right for a particular thickness. I mean .035 wire runs from approx 16-20 volts for optimum. Not too broad of a range so it should be fairly easy to dial it in. On the 115v wire feeds you get a little range with 023 but 030 is pretty much wide open and adjust the wire.
Maybe you should have bought a different welder.... Door charts are pretty much standard on big name units....
Dale
That’s an odd comment.
No... Just saying that its a short coming of a particular brand... Sort of like a steering wheel missing on the new car you buy.... Maybe you should buy a car that includes steering wheel....
Dale
Dale
Not hardly, it would be more comparable to: just the driver's license manual is not included with the car. If you buy a car, you don't expect training and the knowledge required to drive it to be the car company's responsibility.
