Toro GT2300 bogging down
   / Toro GT2300 bogging down #21
The white wire leading INTO the control module that is screwed to the shrouding should be correct.
Ok. That makes sense. What happens to the red power wire to and from from the module?
   / Toro GT2300 bogging down #23
You can neatly nip and insulate it.
It's a 12 volt power lead, correct? If so I can use it for an extra headlight.
   / Toro GT2300 bogging down #25
I suppose if it isn't too power hungry. Are you up and running?
Unfortunately, no. I had a long work day. Hopefully tomorrow if I don't end up filling in for someone who doesn't show up for work.
Well. the deed is done and it didn't change a thing. I did the conversion this afternoon. When I went out to test it, I mowed flat, uphill and downhill sections. Downhill was the only time it didn't bog. There was one change though. When I shut down the engine, it backfired. That has never happened before. It might be because I didn't throttle down like I almost always do. I'm starting to wonder if the electric clutch for the mower deck is drawing more amps than it should. I'll have to see if I can test for that.
I have my doubts it could be internal. My compression test on both cylinders showed 140. Any thoughts?
   / Toro GT2300 bogging down #28
pull the plug wires one at a time to confirm both cylinders are firing.
   / Toro GT2300 bogging down #29
No, do not pull the plug wires with it running. This can damage the capacitor in the module. Ground the terminal or hook a spare plug up one at a time and ground that. Some clutches can pull lots of current which you can detect by monitoring your battery voltage when the switch is pulled. I'm not sure though how that would be related to a power loss. I'll review your thread.
I was definitely not planning on pulling any plug wires. I've already checked the spark with a spark tester. I am going to retest the compression to make sure I didn't miss anything the last time. The tractor seems to run fine until the mower is engaged. I'm going to follow that path to see where it goes. I'm hoping I'm wrong as replacement of the clutch is expensive.
2012 KENWORTH T800 (A50854)
2012 KENWORTH T800...
2015 Isuzu NRR John Bean 700 Sewer Jetter Vacuum Truck (A49461)
2015 Isuzu NRR...
WEATHERFORD TRIPLEX PUMP WITH ELECTRICAL PANELS (A50854)
WEATHERFORD...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
2013 MACK PINNACLE CHU613 DAY CAB (A50854)
2013 MACK PINNACLE...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
