JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,021
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
That nice sharp, stepped shoulder machined into the hole doesn't help either.
MF list the front axle as cast steel, haven't found any info on rear axle material.
I'm not so sure. I have mixed feelings about the ribbed post. That design allows one to tighten the post while maintaining solid contact in the hole without depending on washers or external landings on the post. If it were threaded all the way thru the hole you lose solid contact internal with the casting. No matter, there are larger issues. The OP just has to let the dealer either repair the tractor or replace the whole darn tractor which I think is the right thing to do with 3hrs on it (!)
While there are MANY tractors & brands with the single end supported pin/anchor for the lift arm, the others I have seen (incl. my own 'Botas) have a much thicker, heavier pin AND the support material is mild steel rather than cast. Bends instead of breaks. I think MF made a mistake in that design. The casting looks plenty heavy but experience proves that wrong. We will never know how many units have failed but it is NOT rare. As a practical matter, I'd like to see AGCO/Massey come out with a retrofit kit that bolts on to provide two sided support for a heavier pin.
