Input on a high volume, low weight hauling need.
   / Input on a high volume, low weight hauling need. #11
I have a two-prong hay spear on my FEL, the spacing of the spears fits a standard pallet. I built/modified a pallet with flooring, back & sides and attached it to the backstop of the attachment with rope.
Primarily I use this to collect chips from my chipper and then transport/dump the chips/mulch where I want it. I don't see why this couldn't fit your needs.
... bugger! I can't upload a picture. :mad:
   / Input on a high volume, low weight hauling need. #12
If all you need is a larger bucket for your tractor to haul more at a time, how about getting something like this and strapping it to bucket forks on your fel.
35 Gallon Blue Rectangular Open Top Tank | U.S. Plastic Corp.
I agree. A larger bucket for lightweight material.
Someone on the PowerTrac forum made a large bucket out of an old heating oil tank removed from a basement. Just weld a few gussets here and there for strength, and a QA plate for a skid steer quick attach and off you go. You could leave it in the barn until it's full, then pick it up and go.
   / Input on a high volume, low weight hauling need. #14
Here it is. Username is Stray.
Description of build starts here:
https://www.tractorbynet.com/forums/power-trac/48067-large-bucket-container-2.html#post547868
31406d1103683528-large-bucket-container-551225-large-bucket-jpg
   / Input on a high volume, low weight hauling need. #16
Build yourself a manure catapult. Call it Fling-**it-Hi.
Evacuate and spread it all in one motion.
I've thought about running gear and building a dump bed for it. Those Jr. running gear are low enough that it would work well. I like having 4 tires on the ground which makes on/off the UTV easy and quick. It can also easily be dropped at the barn and the UTV used otherwise. This is one of the reasons a bigger bucket really isn't an option, I'd like to find a dedicated 'mover' which doesn't restrict using other equipment. Changing out a bucket and/or dedicating my tractor to this task isn't putting it to its best use for me. I appreciate the thought however, and it would likely address the problem, if not for this issue.
Peter, what/where did you get that trailer? I've looked online, and not had any luck in finding a small dump that size. I'd still rather have an electrohydraulic for a UTV, but that would work for my needs.
   / Input on a high volume, low weight hauling need. #19
I got it a few years ago its made by Cam Superline trailers I don't know if they still make it ,But you could get the battery hydraulic pump for it as a option..Really any small 5x8 dump trailer will work.....
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
