Western snow plow on John Deere
   / Western snow plow on John Deere #1
tude
Knoxville PA
John Deere A
The Western snow plow is attached to grandfathers 1946 John Deere A. My brother still has both the tractor and snow plow.
   / Western snow plow on John Deere #2
That tricycle front would be a bugger to plow with. I run a 10 foot retired power angle county plow on my M9000 Kubota FWA and it's a bear at times.
   / Western snow plow on John Deere #3
Just have to rely on steering brakes I expect. That setup has a big red beam going to the rear. So it will be a much more solid mount than floppy loader arms flexing away. It amazes me how much my loader flexes when plowing & doing other normal bucket related loader tasks. That setup may or may not run into issues with the front coming off the ground in float either due to the better geometry.
   / Western snow plow on John Deere #4
Rugged looking setup for straight pushing.
   / Western snow plow on John Deere #5
Interesting. My loader don't flex at all. Maybe your bushings are shot. They do wear out, especially if not greased every 10 hours. That really has nothing to do with plow steer anyway. The plow is steering when you push a lot of snow because the weight of the snow deflects the plow (and the tractor) from your desired line of travel. I run chains on my front tires in FWA and none on the back.100_0008.JPG100_0003.JPG
Second picture is plow steer from the weight of the pushed snow. With a tricycle front, it would be much worse especially with no FWA. You can brake steer all you want to, it will not alter the direction the plow is taking as the snow forces it (and the tractor) to one side or another.
I do this stuff all the time in the winter. I open that road for a mile to the pavement.
   / Western snow plow on John Deere #8
I much prefer frame mounted plows to loader mounted plows. One of many reasons is the frame mounted blade is closer to the rear axle. That lessens the effect a pile of snow in front of an angled blade has on the direction of travel.
   / Western snow plow on John Deere #9
Both my former L3200 & current L4060 have been this way. I had them since new & grease very often. Bushings are tight at least vertically. There is slop side to side by a substantial fraction of an inch between the arms & frame to slide sideways on the pin from the factory.
I prefer the SSQA plow because of the ease of mounting or dismounting not because of performance. I'm sure that old tractor mounted frame works a bit better.
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
45 Gallon Fuel Transfer Tank (A57454)
45 Gallon Fuel...
20ft Shipping Container (A57453)
20ft Shipping...
Forklift (A59228)
Forklift (A59228)
