/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #541
You guys will LOVE the paint scheme. Hint: I like things to match
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #542
Hey cglaser104 did you put cotter pins in the nuts on the shafts in gear box?
Dale
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #543
Dale
Not yet, still gotta snug down the nuts one final time and then put them in
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #545
Hmm, maybe Red Flames!
KC
Like!
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #546
So I've completely rebuilt the gearbox with cups, bearings and seals. Given that the bottom seal was toast and the bearing wobbled out and the sleeve worn out they had the gearbox full of heavy grease which had to be scraped and scrubbed and cleaned out. I also had to improvise fixing the bottom cup and was able to add a stainless steel sleeve and drive the cup down into it. I shouldn't be surprised a 60+ year old gearbox is that worn out
And now the reason I'm on a GC thread telling you about this. I was also able to test fit the brush hog to the GC. She lifted it without a second thought...of course. LOL. I swear I heard the tractor ask me to hurry up and finish this thing already so we could go thrash some grass but that might have been my imagination.
I hope to get to paint stage later this week after building the front/back supports and tail wheel swing arm/bracket.View attachment 668310View attachment 668311View attachment 668312View attachment 668313View attachment 668314
Looks beasty...nice.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #547
Did a bit bit of driveway work for a friend.
Was able to bring most of it up, and they’ll be able to push off getting more stone for a year or two.
4’ EA BB and FEL.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #548
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #549
I was able to test fit the rebuild on my GC1710 yesterday. I built the tail wheel bracket after these pics were taken and the unit was set on the garage floor for height measurements. Everything looks good and is operating as expected. Today I tore everything back down so that it could be cleaned and painted which should happen sometime tomorrow.IMG_20200905_153959.jpgIMG_20200905_154924.jpg
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #550
Yes. I will have reused the gearbox (which I'm rebuilding with new seals and bearings), drive shaft, tail wheel, and the front and rear metal bands of the original brush hog. I completely refabricated the sides, top, hitch points (making it QH compatible) frame and the wheel bracket.
Edit: I've modified the design quite a bit because of the way the original failed
Oh wow that an impressive project CG!
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #551
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #552
So my dad who lives around the corner by road or down my back yard and hang left to cross 3 other properties that are all mowed had this old engine lift frame sitting in his yard. I needed something hang parts for painting off of with my sprayer and thought this would be perfect for that purpose with such large parts. A set of forks, some old wooden pieces dad had hanging around and a ratchet strap later I drove it home and set it in my yard to hang the brush hog off of for paint. The tractor was plenty of strong enough but with such a tall load it was certainly as much as I would want to handle suspend out like that. Luckily the ground here is mostly flat so large inclines were not a factor.IMG_20200907_144446.jpgIMG_20200907_144613.jpgIMG_20200907_144620.jpg
That engine lift frame looks like you scored for painting big/small parts.
Don't paint the lift frame, if you make it look too nice you might half to take it back...
KC
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #554
KC
Luckily his tractor is an old BX1500 with a fraction of the lift capacity and no SSQA or forks so it'll be far tougher for him to get it home. That frame has been sitting in the hedgerow for at least 15 years unused so I doubt he'll miss it.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #555
Was out stumping Saturday and Sunday.
Needed to take out 6 stumps, got 4 done and found 2 more that I may just cut closer to the ground as they are older, and one that is entwined within another huge tree, may jsut cut that closer to the ground.
2 came out easy with the front loader. 2 Came out not too bad with a lot of BH work.
1 Oak that I had to take out beginning of the year is still there :-(
Went at it for a while with the BH and a swazall, but ran out of steam-cut 3 major roots and a lot of minor one and still it does not move at all...will leave for another day.
Taking one stump for a ride to the stump graveyard:stmpin20200912_133210.jpg
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #556
Taking one stump for a ride to the stump graveyard:View attachment 669626
Nice! I swazall that sort of stuff as much as possible too, to save the chainsaw chain.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #557
IMG_0534.JPGIMG_0529.JPGIMG_0535.JPGIMG_0531.JPGIMG_0536.JPGIMG_0530.JPGIMG_0533.JPGIMG_0532.JPG
Pretty involved job today, remove small stump, grade a bunch, place 11 yards of top soil, excavate walkway and place 3 tons of stone.
Nice project and perfect customer (he was my ground man, and knew what he was doing).
Backhoe, loader and EA BB.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #558
Looks nice and clean now, need a shot to in the spring show how it turns out !
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #559
I enjoy stumping, I’ve pulled out some large ones. Anything over 18” or so across, for customers, I send the grinder after them.
At home I dig them all out.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #560
I'm with you on that! A cold beer and a big stump is a nice way to spend some time.
PONDEROSA PINE TONGUE & GROOVE (A60432)
PONDEROSA PINE...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
PALLET OF SAFETY BOUNDARY (A60432)
PALLET OF SAFETY...
2021 CATERPILLAR 259D3 SKID STEER (A60429)
2021 CATERPILLAR...
iDrive TDS-2010H...
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
