/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,441
Yeh nice deck, composite right? I'm gonna replace my deck with composite sometime...sick of dealing with carpenter bees and having to re-stain it so often.
Moisture shield is the brand, very pleased with it so far. I have a buddy that builds big money decks for a living, he was my “phone-a-friend”.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,442
sunshade mounted.
light bar mount and light, square stock shims inserted each bracket do slim it up, was made for TLB ROPS which is 34 inches wide exterior to exterior of bar, non TLB is 31.5 inches.
front and side shots, its not bent just illusion from angle tractor on hill and where I am standing.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,443
Good to know, I jutted it down.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,444
I'm less ambitious than you guys, but today did add a knob to the loader joystick extension (which I earlier add to the joystick).
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,447
Working on my FEL after losing a few bolts and snapping a couple more. 🤬
I heard a snap when lifting a load and the the bucket leaned to the left. Ooops
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,448
You got lucky! That could have made for an expensive fix!
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,449
True. I will have to extract 2 sheared bolts and replace all 4 and then the one to the left where one is missing but it could've twisted the loader frame badly.
It was no easy chore to line up those holes with the tractor frame.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,450
Moved the third 22ish ton load of fill. Almost at the 50hour mark on her so far. I got it in February. I don’t use it for snow removal.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,451
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,452
Oh I forgot I used a root ripper to cut a path for a in ground dog fence. I couldn’t use it everywhere but where I did it worked well.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,454
finished lights on sun shade. 20" led in back aiming down/out to wards my pto and 2 4" pods (mounted to my tail light hoops) pointing backwards.
then a 24" mounted on front of shade. am gonna put one on each side illuminating my tires on both sides.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,455
Oh that sux, but yeh coulda been a lot(!!) worse. What method you use to line it up, with loader on or off?
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,456
Loader was on but I couldn't get it to line up perfectly so I used a hydraulic lift to raise the chassis frame and then it lined up.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,457
guess what I double checked today :)
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,458
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,459
My Massey GC1723EB backhoe control panel anchor tabs snapped off. This is a simple fix. Two Stanley "L" brackets, a couple of bolts and some Massey red spray paint from Tractor Supply. I cut off the corners on the "L" brackets so they would not rub on the hydraulic hoses. The existing bolts on the backhoe platform matched up with the holes in the "L" brackets. I had to drill two holes for the side bolts. The control panel is rock solid now.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,460
simple stuff.
tilled up 3 45ft rows of peas that were picked clean by me (by that I mean my wife) and deer.
then created, using the heavy hitch row creator, 4 rows and planted approx 160ft of peas tobe harvested early September using 4 seed varieties I had left over.
also tilled areas my cukes, pumpkins, squash are about to spill over into.
simple stuff...now that I that I have a GC...before with old craftsman lawn tractor it was a LOT harder
oh yeah I also rotated my horse manure compost pile, now at 8 loads of a 7x10 dump trailer added onto existing 10 cubic yd pile.
pile running about 9 feet high now.
simple stuff.
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
APPROX. (30) 2"X6"X6' CHANNEL IRON (A60430)
APPROX. (30)...
2023 Chevrolet Tahoe SUV (A59231)
2023 Chevrolet...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
