New (used) IH 7500 Dump Truck purchase, modification & fix up
   / New (used) IH 7500 Dump Truck purchase, modification & fix up
Neat project. I noticed your comment about the 41,800 GVWR. I am not up on PA's axle weight limits these days but that sounds excessive?
41,780 to be exact.
27K rear axle and 14,780 front axle.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #92
I saw that but I was thinking the max allowable on a single rear axle was like 20K? Not sure about the front.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #93
Not trying to be picky. Just thinking about how quick a box of rocks can get pretty heavy. Rate weight and highway allowable weight and all.
Nah there’s 21, 23, 25, 27K rear axles available.
Front axle is a Meritor MX-16 16,000lbs capacity and rear axle is a Meritor RS-30 30,000lb capacity
Sure can. It’s up to the operator of the vehicle to make sure its not overloaded. OTR, I’m pretty careful and take it slow. Off road is where I want the load capacity. It may see 100’s of 10-12 ton loads-driven slow to the dump pile.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #96
Now that's what you want :), nice reinforced tailgate too . Comes with the lift cylinder, trunnion blocks, cradle and hinge I hope? Add a cab shield too....maybe?
If the actual conveyor chain and gearbox is there you could flog that for a few bucks too.
Just the box & cab shield. I have to hunt down the rest :(
But it’s cheap (in todays terms).
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #98
Just wanting you to be aware of the legal limits on the highways. Been quite a few years but me n' PA's scales go way back.
I’m still “enjoying” those PA scales. As long as you arent over on an axle, your registered weight/tag, there's no real issue, unless something’s broke. Been a CDL holder for 30+ years with no serious issues so far
Hit a setback today.
Got bed removed and it sat for 10-15 days.
Arrived Friday to take truck to have frame sandblasted and she won’t start. :mad:
Batteries had plenty of power (note: HAD).
Started with changing fuel filter. The one I removed looked fine. Opened water drain. Did get some water. Close it once fuel was flowing. Installed new element. Crank-crank-crank, but no start. Opened water drain, fuel was under pressure and flowing.
Batteries are pretty tired now.
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
