New (used) IH 7500 Dump Truck purchase, modification & fix up
   / New (used) IH 7500 Dump Truck purchase, modification & fix up
Neat project. I noticed your comment about the 41,800 GVWR. I am not up on PA's axle weight limits these days but that sounds excessive?
41,780 to be exact.
27K rear axle and 14,780 front axle.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #92
I saw that but I was thinking the max allowable on a single rear axle was like 20K? Not sure about the front.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #93
Not trying to be picky. Just thinking about how quick a box of rocks can get pretty heavy. Rate weight and highway allowable weight and all.
Nah there’s 21, 23, 25, 27K rear axles available.
Front axle is a Meritor MX-16 16,000lbs capacity and rear axle is a Meritor RS-30 30,000lb capacity
Sure can. It’s up to the operator of the vehicle to make sure its not overloaded. OTR, I’m pretty careful and take it slow. Off road is where I want the load capacity. It may see 100’s of 10-12 ton loads-driven slow to the dump pile.
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #96
Now that's what you want :), nice reinforced tailgate too . Comes with the lift cylinder, trunnion blocks, cradle and hinge I hope? Add a cab shield too....maybe?
If the actual conveyor chain and gearbox is there you could flog that for a few bucks too.
Just the box & cab shield. I have to hunt down the rest :(
But it’s cheap (in todays terms).
   / New (used) IH 7500 Dump Truck purchase, modification & fix up #98
Just wanting you to be aware of the legal limits on the highways. Been quite a few years but me n' PA's scales go way back.
I’m still “enjoying” those PA scales. As long as you arent over on an axle, your registered weight/tag, there's no real issue, unless something’s broke. Been a CDL holder for 30+ years with no serious issues so far
Hit a setback today.
Got bed removed and it sat for 10-15 days.
Arrived Friday to take truck to have frame sandblasted and she won’t start. :mad:
Batteries had plenty of power (note: HAD).
Started with changing fuel filter. The one I removed looked fine. Opened water drain. Did get some water. Close it once fuel was flowing. Installed new element. Crank-crank-crank, but no start. Opened water drain, fuel was under pressure and flowing.
Batteries are pretty tired now.
2017 Kubota M7-151 Premium MFWD Tractor (A56438)
2017 Kubota M7-151...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2022 FORD F-250 CREW CAB TRUCK (A59823)
2022 FORD F-250...
Leer Camper Shell (A57454)
Leer Camper Shell...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
2016 Ford Explorer SUV (A56859)
2016 Ford Explorer...
