Leaking hydraulic pipe from pump to “PTO Solenoid Valve”
   / Leaking hydraulic pipe from pump to “PTO Solenoid Valve”
Do you have any way to plug one end of that tube and then pressurize the tube with air or oil to see if it leaks. A pin hole or hair line crack should show up.
I plugged one end and used my mouth on the other to pressurize. Held that pressure no problem. I suppose it must be leaking from the actual flare area. There isn’t a chance that there’s something blocked up in the solenoid valve area that would over pressurize it, is there?
   / Leaking hydraulic pipe from pump to “PTO Solenoid Valve” #12
Doubtful something in valve could cause over pressure but anything is possible.
Deere 35P (A53317)
Deere 35P (A53317)
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2018 PRINOTH...
Enclosed Service Truck (A55788)
Enclosed Service...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
Kubota RTV-X1140...
John Deere 980 Field Cultivator (A59814)
John Deere 980...
