Leaking hydraulic pipe from pump to “PTO Solenoid Valve”
   / Leaking hydraulic pipe from pump to “PTO Solenoid Valve”
Do you have any way to plug one end of that tube and then pressurize the tube with air or oil to see if it leaks. A pin hole or hair line crack should show up.
I plugged one end and used my mouth on the other to pressurize. Held that pressure no problem. I suppose it must be leaking from the actual flare area. There isn’t a chance that there’s something blocked up in the solenoid valve area that would over pressurize it, is there?
   / Leaking hydraulic pipe from pump to “PTO Solenoid Valve” #12
Doubtful something in valve could cause over pressure but anything is possible.
WOOD GRABBER FOR MINI EXCAVATOR (A53843)
WOOD GRABBER FOR...
AT 26in x 11-12in (A52377)
AT 26in x 11-12in...
WOOD GRABBER FOR...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
