Leaking hydraulic pipe from pump to “PTO Solenoid Valve”
   / Leaking hydraulic pipe from pump to “PTO Solenoid Valve”
Do you have any way to plug one end of that tube and then pressurize the tube with air or oil to see if it leaks. A pin hole or hair line crack should show up.
I plugged one end and used my mouth on the other to pressurize. Held that pressure no problem. I suppose it must be leaking from the actual flare area. There isn’t a chance that there’s something blocked up in the solenoid valve area that would over pressurize it, is there?
   / Leaking hydraulic pipe from pump to “PTO Solenoid Valve” #12
Doubtful something in valve could cause over pressure but anything is possible.
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60460)
2017 Peterbilt 567...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
12' CONTAINER (A52706)
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
